Pool water and outfitting?
Hi there,
My school is organizing pool sessions at the local pool, and I was thinking of taking my OC1. I was wondering if the chlorine in the pool water would do anything to the outfitting or airbags in my boat? I know the concentrations of chlorine aren't extreme, but I don't want to wreck my new (to me) boat.
I used my OC in a pool a number of times while learning to roll with no noticeable afteraffects. I did make sure to rinse the bags, PFD, etc, and with wood gunwales pay attention to the finish (I was oiling them periodically anyway).
Yea, we've taken our boats and followed the same protocol. Stand in the shower with the bags and shampoo. This probably doesn't apply to your warmer location but on some of our sub -30c nights, the instant freeze and wind chill on top of the truck after being warm and wet we believe loosened up some of the foam,(we had to re-glue a knee block) just keep and eye on it.
gunwale shrinkage
yes, i have read that wood gunnels shrink at different rates than the abs hull, so paul mason, recommends to loosed the screws nearer the bow and stern, while the mid-boat screwsare less affected, yet the others should be loosened, with vinyl, the shrink rate is basically the same as the abs plastic, so no loosening is necessary.
-isaac
-isaac
pool sessions
In Ontario the minimum for swimming pool sanitation is .5mg/L Chlorine, the stuff coming out of your taps will be around 1.2mg/L if your feeding off the Great Lakes.
Hmmmm
Chris Mack
Hmmmm
Chris Mack
