I just did a practice plate on my old Ovation. I was trying to use as little epoxy as possible in order to keep the plate from being heavy and brittle. I had done a skid plate before by soaking the felt in the resin and then squeezing as much of the excess resin out of the felt as I could with gloved fingers. I did the cling film trick and it looks great and hasn't shattered- but looks heavy.
For the plate I put on recently, I slathered a bunch of epoxy on the hull, pressed the felt into the epoxy, and where the felt didn't look saturated I dabbed at it with more epoxy until it looked uniformly saturated- but only just. It looks pretty good, seems to have adhered well, and definitely looks lighter weight and less brittle- BUT IT REALLY LOOKS LIKE FELT! Despite using cling film again, the finish is fairly nappy, there are some small spots that look like they weren't fully saturated with epoxy, and the whole thing looks like it might be pretty "grabby." I don't see how that material could be a slick as Royalex, and I'm worried that if I use the same technique when I do the skid plates on my Phantom (which I bought primarily for sliding down steep piles of wet rocks) that the stern plate will catch.
I did the stern plate on the Ovation mainly as a practice run for putting lightweight plates (also with pigment in the epoxy) on my Phantom. Problem is, I can't tell from looking at the finished plate whether it's any good or not- and I'd like to avoid paddling the Ovation to find out
![;-)](./images/smilies/icon_wink.gif)
So...
Is a skid plate with a still felt-like feel acceptable? Will it hang up boofing on low volume creeks?
Can/should I retroactively dab more epoxy on the felt where it seems not fully saturated? Given that the "soak and finger squeegie method" that I used long ago on the bow skid plate is easier, and doesn't seem to make the plate so brittle that it cracks upon impact, is the resin-light method that I tried recently even worth it for the modest savings in weight? What could the weight difference btwn a set of resin-heavy and resin-light skid plates be? 5-10 ounces? Mind you, I'm one good sized sandwich away from being too heavy for the Phantom, so weight savings is pretty important to me.
Kevin
