Last weekend I took Mohawks Phiend Prototype out and decided to see if I could get some good pictures of it running some stout drops that wouldn't put too big of a hurt on me or the fragile glass canoe. Here are some of those Phiend Pictures and the Facebook discussion to carry on with here.
CREEKER WROTE: I thought we could share some ideas on running bigger drops and how we prepare for it. To me Big is anything 10 feet or bigger. Agreed going big isn't everyone's cup of tea or bottle of Jack. I don't do it for Adrenaline and I don't think it makes me a great boater, but it does require some specific skills to do well that are worth sharing. So please share your experiences as well even if its just that 10' drop you've been working on getting. Personally I boat for challenge and I want to see if I can do a drop. I also love photography and BIG is eye candy for camera.
I try to tip over the lip as adrenaline free as I can. So was the case on Saturday here. All my Adrenaline was on Friday night when I was deciding to pack, when I thought that I saw favorable water levels for 16 hours later. Pictured is a touchy lip to get to in the right orientation with the rush of flow at the lip. There is a turn your back on the waterfall ferry move at medium to higher water that I really don't like and anticipation of what that level would be was making my palms sweat right up till I saw the flow of the day. Forget about all the logs to sync your peal out around in the gyro eddy. Its quite nuts at times in there after you rope lower in but that would be just having to make it work once you got in there.
CREEKER WROTE: 1. do your back a favor cut plugs out of your saddle. Locate exactly were your butt bones press into the saddle. Granted foam is soft but not soft enough in a critical hit. Pull plugs out about 1" under the top foam of the saddle. Your back will love you for it if your cut your boof too tight into a green pool or boof into hard water. Yes there is hard water. Not all white stuff is created equal. I've had friends boof Ohiopyle falls and break their back from a perfect boof.
CREEKER WROTE: On Saturday I totally forgot I didn't do this saddle mod in the Phiend till it was too late. I left the plug maker in the garage, yet I was committed (in my mind) to getting a nice pic for Richard....I'd just have to land it right. I ran the drop 2x on Saturday. The other time was with my Ledge which had the softer saddle tweak. The Phiend landing was a softer entry near 45 degrees but more vertical 55-ish? Thats an easier landing on your back and I was really happy with it. The L'edge landing was a flat stomp down. The Phiend landing which should have scrubbed off more pressure was much harder than the flat Ledge stomp....the ledge saddle mod made months ago performed well when I needed them. There is other stuff about this drop I could share but I thought I'd kick it off with that for people to think about GO BIG glory hunting.
CHEEKS WROTE: That's a sweet tidbit Wayner. I've been looking at going bigger and I was wondering what the general consensus on boofing was. I see videos of kayaks boofing straight out on 30'-40' foot drops like center line at Little River Falls and Double Drop in Norway.
Can canoes do that too or would the larger impact surface make that too dangerous? Let's pretend that we can water boof completely flat.
CREEKER WROTE: Well Cheeks with shades of gray off of perfect form I think the water curtain can easily help flush your tail down and you can catch an air draft up the curtain to amplify any boof out mistake. A whole lot can and does happen in the 1 extra second of freefall between a routine 20 and a 40ft drop. A straight out 30-40 foot boof is not the kind of drop I'm planning to do on purpose.
CHEEKS WROTE: I agree, although I think that stern pressure stems less from the boof and more from the inability to get away from the curtain. I've had a complete 270 degree backender at Ohiopyle from missing my boof and penciling in.
CHEEKS WROTE: I'm wondering if I could do this in a canoe or if I'd break my back on the first drop. I am in no way comparing my current ability to Evan Garcia btw, just wondering
https://vimeo.com/47470696" onclick="window.open(this.href);return false;
Best Line Entry - EVAN GARCIA (USA) - Double Drop - Norway
GM Wrote: CREEKER, what do you mean by cutting a plug out of the saddle to soften it? Are you cutting a hole all the way through the saddle about 1 inch below the seat. I so, how big is the plug?
GUMPY WROTE: I like to think that if I'm coming down flatter than intended, i throw a quick tilt, usually to my onside. Instead of feeling it mostly in my spine I'll take a shot to the knee. Still hurts, but less dangerous. Creeker tell me more about your saddle mod.
Louie Wrote: "any thing under twenty feet is just a ledge" Mike Yee 1995
10 hours ago · Edited · Like · 2..
RODEO CLOWN WROTE: Cheeks, the key to landing boofs from height is body position. You'll notice in the video you posted of Evan is he's leaning way forward after he boofs. This does too things: let's you stomp the bow down (the so called 'boofs stomp) and prevents axial loading on the spine (compression). Instead your body's momentum will be carried forward, whip lashing your face into the hard deck in a kayak, or the soft airbag in a canoe. Canoes do land harder, the additional rocker and volume means they tend to flatten out more on landing. The nice thing about running waterfalls is they scale well, you can practice the techniques for either boof-stomping or plugging a bigger drop on Something in the 15-20 foot range.
5 hours ago ·
CREEKER WROTE:
The Impact Saddle Modification: Spend some time in your canoe and really settle in on the perfect height of your saddle. Its pretty simple, take a piece of PVC pipe and taper the end in towards the inner diameter to make a plug maker for the size of the inner diameter of the pipe. My plugs are 1" & the PVC length just fits between the side of the saddle and the inner sidewall of the canoe or bigger if out of the canoe working. I did my mod after I had recently put the saddle back in the L'edge. Ideally its better to do it on a pulled out saddle where you can lay the saddle on its side on the corner of a work table with the thigh hook hanging off and drive the tube though the saddle *square* from one side to the other level with the seat surface. Expect you might have some tearing in the middle where the seams of foam meet. Afterwards I thought about spraying teflon on the outside only of the PVC to help it move easier though the foam or carving a little notch in the tube like a single saw tooth that would do a little cutting as well. You locate the spot of max pressure under your butt bones and pull foam plugs out in about a 3"-4" lengths from each side with them meeting right under your tail bone. Extract the plugs and you are done. One side to side hole seemed good to me but I decided to go with two and they are 1" apart and I feel I move around on the saddle quite a bit leaning hard on one butt cheek or possibly that extream j lean landing Gumpy was mentioning above...it all gets a little softer is the thinking.
JW Wrote: I have no experience to contribute, but I thought James' video on boat angle was the most interesting thing to come out of the infamous "water boof" thread: http://vimeo.com/22716207" onclick="window.open(this.href);return false;
Cheeks wrote: Thanks Rodeo Clown, that'll be something good to work on
Creeker Wrote You can put a 1" hole in your thigh hooks between your femor bone and where it would rise up to press foam hard against the support of the Thwart say in bow hit piton. All I'm looking at doing is scrubbing off the max pressure against soft tissue and distributing it over a few extra tenths of a second VS a couple hundredths. It's what car crumple zones are all about for auto safety.
Richard Guin Wrote When I build a boat for myself for hard paddling, I do the plug trick is the bulk head and on the saddle. I also cut a center groove out of the saddle and put a layer or two of soft foam down then cover it with knee pad foam this helps spread the hit out.
Mark Zakutansky Wrote I like this thread and want to tinker with these ideas. I have noticed my thighs get bruised after bigger drops and big runs.
CREEKER WROTE: that entry angle worked in the video Johnathan posted above at the ORO (mexico)...not so much here at MINUTE 1:15 That bow lift or tail flush or combo in bigger drops is worrisome. http://www.bombflow.com/archives/bomb-f ... -northwest" onclick="window.open(this.href);return false;
