behind the knee bulge
pblanc
Re: behind the knee bulge
Post by pblanc »
If you are tempted to stick a needle in it, just be certain it isn't pulsating first. Popliteal artery aneurysms are much less common than Baker's cysts but they do occur.
A cyst that large can cause symptoms as a result of nerve compression in the popliteal fossa. There are some pretty important nerves in the vicinity. You would be well advised to see a physician.
hazardharry
Post by hazardharry »
most of you make me want to puke. :oops: sticking things in things. man i'see a med soon. :roll:
Rand C1
Post by Rand C1 »
I had a problem with a bakers cyst that was relieved when I had a torn meniscus repaired(minor knee surgery). The cyst no longer occurs. See a doctor.
Rand
Good point, Rand. The problem isn't in the Bakers Cyst, it's somewhere else.
icyone
Post by icyone »
No joke!
Definitely see a doc -- & I always recommend someone with a sports med specialty because they are usually more understanding of people who don't want to lie around indefinitely.
I had a popliteal cyst in conjunction with major meniscus damage. It was not nice. I suspect that such a cyst quite often is there for a reason of some sort, & I would recommend not being your own doc, unless you are one.
Good luck
C-1's are the Gods of the River
