Which C1 for this open boater?
Re: Which C1 for this open boater?
No, as I said before, modern slalom boats are very easy to get used to, on easy water. I would hope you'd have some class 1-2 water and gates to get used to it, and get your combat roll established, before you get back on that Olympic course.
If I were trapped in a state with no river harder than the Nantahala, I'd rather have a properly sized slalom boat than any other c-1. They are simply more controllable. They front surf and handle green waves. Side surfing.....not so good.
Pea Pod
Post by Pea Pod »
ezwater wrote:No, as I said before, modern slalom boats are very easy to get used to, on easy water. I would hope you'd have some class 1-2 water and gates to get used to it, and get your combat roll established, before you get back on that Olympic course.
Sadly, there's only flat water with gates, no Class 1 - 2. In fact, it's been so dry, there's probably no Class 1 - 2 within a 10 hour drive! (It ain't easy being a paddler in the driest continent on Earth.)
ezwater wrote: If I were trapped in a state with no river harder than the Nantahala, I'd rather have a properly sized slalom boat than any other c-1. They are simply more controllable. They front surf and handle green waves. Side surfing.....not so good.
If I'm buying a used slalom C1, how do I determine if it's properly sized? Are there any other features I should be looking for, considering I'm a newby?
By the way, I don't get the Nantahala reference. Would you please elaborate?
