This Mohawk Viper 12 is in pretty worn, but repairable shape.
The chines near the center are worn through the outer ABS, I'm told you can patch it with ABS (I could never get it to take the shape) or you could go with glass/kevlar. I patched them with glass and it has mostly worn off.
The bow suffered a pretty hard piton and is fractured - the deck plate has a split as is the royalex, these fit together pretty tightly, are well above normal water line, and are repairable as well.
There is a very sound ABS patch covering wear under the saddle.
There is an ABS putty/kevlar cloth reinforcement inside under the pedestal/ over thigh strap anchors.
The vinyl gunwales are sound. No wraps.
It was originally blue, but has a coat each of blue and red (on top) vinyl paint.
$75 bucks if I keep the pedestal, $100 if included. Beer or other interesting comestibles concidered. A set of leaky but usable air bags included. Pictures available. Boat is in central SC, but could probably be delivered to the Armada (PA/MD/WV) or some place in between.
This boat has to go. It's got some life left in it, maybe a lot if you want to repair it. No pedestal. I'll thow in some bags, leaky but serviceable. I'm going to GAF - make it worth my while to load it and it is yours. Case of good beer? A tank of gas?
It's next stop is a viking funeral or maybe it becomes a planter or sand box...
