Check this out, a new gadget from EJ:
http://www.jacksonkayak.com/designs/footbag.cfm
Now picture similar replacing your minicell bulkead in your C-1. Hop in it in the summertime and inflate a lot to fit - in the winter, over a dry suit and layers, inflate it not so much. In an OC-1 you'd need something to restrain it on the top, maybe fit inside a very wide open bulkhead and use the "bladders" to fill it out.
I've a sort of adjustable bulkhead in one of my boats using a floating block and some strapping (early version:http://bookwoman.net/scott/pix/buckle_in_boat.jpg). This could be more like a "Nike Pump Cockpit". Anybody else see it?
idea...a way to make real the adjustable bulkhead?
