Newbie Royalex repair questions/Anyone OC1 near Cincy?
Posted: Sat Dec 23, 2006 6:50 am
First, Hello. I've been lurking for a while. I'm glad I've stumbled across this site; others like paddling.net are good, but as a (budding) canoer, I feel like the distinct minority over there. Even the local web/paddling group (Cincinnati) seems almost exclusively pro-kayak.
I started out in a Dagger Blackwater kayak (which I'll keep and still enjoy), but the used tandem Mohawk Blazer RX I purchased to introduce my son to paddling pulled me back into canoing. I picked up a well cared for but battle worn Mohawk Challenger (14 ft. solo river tripper) this past summer and figure it could use a little TLC while in dry dock for the winter.
The Challenger has the normal stem/stern/keel wear from run-ins with gravel bars and rocks, with a single small pea sized spot where the vinyl and ABS wore down to the foam core. There's no indication of rot, so I figured I'd build up the lost area with J.B. Weld. From there however, I'm not sure if a light coat of J.B. over the rest of the abraded area will hold up or weather I should step up to West Systems epoxy, with possibly a sheet of glass cloth thrown in for good measure. My current and foreseeable paddling future doesn't really neccessitate full blown (thick) kevlar skid plates and quite frankly, I don't want to rob the boat of any of it's meager speed. The Challenger is my learning vessel and will certainly kiss rocks with me at the helm however, so I may want a little extra protection if J.B. or similar epoxy isn't up to task.
There's also an almost imperceptible 3/4 inch wide "fracture" perpendicular to the interior keel line in the stern of the boat where heavy strain broke a D-ring patch loose shortly after it was installed. The previous owner said the D-ring popped out years ago and was unaware of the crack. I suspect it's only a fracture in the inner vinyl layer, but I'd like to bolster it for good measure. Would drilling tiny stress relief holes and filling with thin epoxy suffice?
Finally, what kind of OC1/C1 paddling resources are around the SW Ohio area? I've been kayaking for about 2 years and was thinking about taking a skills/roll training class at the public pool this winter, but I'm ignorant of any canoe technique classes, resources, etc. in this area. When things "click", I can make the Challenger move out, but other times my technique is a frustrating mess.
Thanks in advance for any thoughts or ideas you share,
Phreon
Phreon
