Ottawa River Armada in July or September
I am thinking of organizing an informal Ottawa River Armada on either the July (Canada Day/ 4th of July) or the Labour Day long weekend.
Rivers that are nearby and have pretty much guaranteed good water levels are, next to the Main and Middle channels of the Ottawa, the Gatineau (~1.5-2 hours away) and the Rouge (~2.5 -3 hours).
Potential rivers, if levels cooperate, (more likely running, if at all, in early July than in September) are the Petawawa Town Section (~ 45 min) and the McDougall section in Algonquin Park (~2 hours away), as well as the Lower Madawaska (~1-1.5 hours).
if there is enough interest I would try to reserve one of the group campsites at Riverrun, which is located right at one of the takeouts for the Millde and Main channels of the Ottawa. It is also the place where the Martin and Gwyn of Shaggy Designs hang out in the Summer, so there will be demo boats available.
Cheers!
PS: The Ottawa and Gatineau are big water and deep, both pool-drop character, with tons of playspots. Both are class 3-4, and all the rapids have easy walks around them.
The town section is (at least at the levels I have run it) a bit harder. The McDougall section of the Petawawa is, if still running, a fun class 3-4 creek in late June or early July.
The lower Madawaska is a class 2-3 run, most likely near minimum runnable level in early July.
Cheers!
Last edited by the great gonzo on Wed Apr 11, 2007 5:18 pm, edited 1 time in total.
How about the weekend after the 4th? I have that off already!
As for the name of the thing ....how about ..."Totally Gonzo-Fest"! I can just image a T-shirt!
As for the boat .. I already have one of those. It was built in the 50s, weighs a ton and is not quite bomb-proof (slight bent - due to paddler error)! But Martin can pull out a newer design I might be interested! The darn things last for ever and there is nothing like pulling off an "aluminum rock slide" on the river!
He could go into his work after hours and have his boat tested to be bombproof - but that would cut into his paddling time...so my guess is he won't get into boat design!
Here's some local folklore about The Great Gonzo, aka Martin! I do this to entice folks to make the trip
Warning: If you have a sensitive stomach with the "kayaker vs cboater" debate, you probably shouldnt read this thread...
http://www.boatwerks.net/boaterboard/vi ... james+bond
-- Cya
- BlackFly Canoes
Gonzo-fest
Martin,
Great idea, count me in. Labour Day may be best, there's usually less boaters on the rivers by then.
Geoff
Geoff
Well, if anyone was looking for me at riverrun or anywhere else on the Ottawa this coming Canada Day long weekend, don't .
I just learned today that I won't be able to get back from my business trip in time and will therefore be stuck here in Sweden for the weekend (well, at least Sweden is not the worst place to be stuck in... ...).
PAC, in case you still plan on coming to the Ottawa for the weekend after, I am 99% sure that I will be able to make it back for that one and I should get some time off to compensate me for the lost long weekend.
Martin - thanks for the heads up. Right now its not looking like we would make it anyway - he just has not got in enough paddle time for me to be comfortable with him in bigger water. Working on it but not there... yet. Hate to take him there and then have his paddling buzz shaved - scaring him and such. Maybe next year. Thanks for the invite and offer. Paul C.
PS: If things change I'll let you know - I"D REALLY LIKE TO BE THERE!
