How do I make gel-coat slicker?
Mike W.
Post by Mike W. »
It's old & oxidized gel-coat. I've tried Maxi-Glide & it helps, but I'd like something that lasts longer. Any thoughts?
tennOC
Post by tennOC »
Try wet-sanding w/ 2000-grit sandpaper. If it's real bad you may have to use 1000-grit first.
philcanoe
Post by philcanoe »
tennOC wrote:Try wet-sanding w/ 2000-grit sandpaper. If it's real bad you may have to use 1000-grit first.
that or...
could try a orbital sander and some good rubbing compound... get one that's 2000 grit or better
bobthepainter
Post by bobthepainter »
wet sand, then buff... do both. :wink:.. or tape it off and shoot it with a fresh coat
Mike W.
Post by Mike W. »
Thanks for the help! Looks like I've got some sanding in my future :-? I think it'll be worth it though. It's only supposed to get up to 101 today :o , so this project is shelved till fall.
Only 101? We hit 106 yesterday and are on our way back... At least Wednesday they relented and released some water on the Saluda...
Mike W.
Post by Mike W. »
Yesterday was 105, but I'm way up here in the North. Tuesday we caught the spike. Flow went from 2,800cfs to 15,000 :D There's a wave at the top that I've been trying unsuccesully to catch for years :cry: & Tuesday I caught it in the Sith :D It's even more amazing than I ever thought it could be :P The guys I was with said that I was on it for over 10 minutes 8) It's ~3' high, glassy w/ just enough of a foam pile to keep you from blowing off 8) The Sith makes a neat "ssssssssssszzzzzzzzzzzzzzzzzzzzz" sound as you carve :P
