Page 1 of 2
Paddle Choices
Posted: Wed May 28, 2008 8:36 pm
by fleckbass
I'm looking for a new padddle to use for an OC-1. At this point, I'm leaning towards something that is not spooned. This reason why is I switch hands and think it will be awkward. I'm not sure if this will be the case or not. I currently have a Werner Nantahala 56" I'm not happy with the flutter and I may need to go up in lenght also. Any thoughts here? I would like to have some durability also. I can be tough on the blade at times. This paddle will basically be used for river running, mostly medium to small voulme. For example, Lower Yough or smaller sized streams.
Posted: Wed May 28, 2008 10:39 pm
by Craig Smerda
wood shaft with a carbon covered curved blade... as long as you are paddling forward you should have no issues as that's what 99% of us are using. when are you getting this supposed "flutter"?
clinch river or mitchell are my weapons of choice
Flutter
Posted: Thu May 29, 2008 12:33 am
by fleckbass
Paddle dances from side to side during forward stroke.
Posted: Thu May 29, 2008 3:00 pm
by PAC
I have a few different sticks you can check out. Most are spooned and mostly composite and wood mixes.
Might be worth while hooking up to check them out. Just let me know when you are about.
Where is your hand placement when the fluttering occurs? Try moving lower hand down an inch or so. Just a thought!
Posted: Thu May 29, 2008 3:57 pm
by kaz
"....dances from side to side"?
Maybe the blade is too wide?
JK
Replies
Posted: Thu May 29, 2008 5:20 pm
by fleckbass
From what I am gathering here. I should look for a spooned blade that is made from wood but covered with carbon. Shaft should be wood. I looked on Mitchell's site and saw a paddle like this. Any other manufacturer recommendations? Also, can anyone comment on length? PAC, I will most likely be at the North Branch this weekend. I noticed you are from Pittsburgh. I'm not sure if I know you or not. I can try to lower my bottom hand and see what happens. Don't think the blade is too wide. Maybe the transistion area below the throat isn't flat enough.
Posted: Thu May 29, 2008 6:34 pm
by PAC
fleckbass since you will be at the Armada just bug everyone you see to try their paddle (explain your current "issue") and you will have more info than you can process.
In the past we have stopped at Keith Blachland's maker of very fine paddles (wood, wood and fiber, and even bent shafts -
http://worldkayakblogs.com/billsblog/20 ... nd-paddle/). If you have interest he might be talked into opening up on Sunday for you. He is sort of on the way home from NBofP to the Burgh. We are also stopping at Jim Snyder's on Friday - another artistian when it comes to making wood paddles (check out
http://www.jimisnyder.com worth just reading the site for information for a zen master). Walt J. (polar paddles - some video
http://www.brightcove.tv/title.jsp?titl ... =824009768 ) in Friendsville also makes a very nice stick (sbroam will be at the Armada and will be picking up some repaired sticks from him I beleive).
Everyone has preferences - some like spoon others hate them. Some like all glass others are fond of nothing but wood! Demo, demo, demo!
Find what you like then make it yours! Paul C.
Length
Posted: Thu May 29, 2008 7:27 pm
by fleckbass
Anyone want to comment on length?
Length
Posted: Thu May 29, 2008 9:33 pm
by Jim P
Bruce,
Length is a rather subjective subject. Run some searches on this site, there have been several discussions in the past.
I will pack a Jimi stick for the weekend you are welcome to try. IMHO, the least flutter you can get in any situation.
Posted: Fri May 30, 2008 2:19 am
by philcanoe
i believe that kayak paddles are spoons, while canoe paddles are curves
Paddles
Posted: Fri Jun 06, 2008 9:44 am
by raven3693
Just don't waste your money on a Galasport. I bought their "creeking" paddle used it less then 6 months and the shaft broke
I did contact Mitchell and they wrote this
I can understand, but I can also assure you that one of our
paddles, if properly maintained, will last much longer than six months.
Because of the nature of the paddle and the wood core, we can maintain
paddles for many, many years. Because the wood core is so stable, we
are able to replace the aluminum tips easily when they wear out (which
they will), we can replace edged, or we can completely strip the carbon,
edges, tips and rebuild the entire blade back to a new condition. Even
if you break the blade in half, it can usually be put back together.
This is one of the major advantages that we have over many other
companies, many of which will not do work on their own product, let
alone other manufactures products. The initial investment many be a
little higher, but the longevity of the product will offset that in the
long run.
Re: Paddles
Posted: Fri Jun 06, 2008 2:27 pm
by oopsiflipped
[quote="raven3693"]Just don't waste your money on a Galasport. I bought their "creeking" paddle used it less then 6 months and the shaft broke
[quote]
I have been extremely happy with my Galasport. It has held up to alot of creeking in TN and banging down the cement ditch in Charlotte. It seems ok in big water, too. That being said it may break or be lost tomorrow, but so far so good.
Paddle Choices
Posted: Fri Jun 06, 2008 2:30 pm
by edg
Another good point about Mitchell is that they can and will do custom work. My "race" paddle is a discontinued Gala blade- very light, very thin, very fragile. I once snapped one and had to run this rapid with half a blade:
http://www.doubledutchuk.com/
It was traumatic. I had Mitchell copy the shape, but with their carbon over wood construction- a bit thicker, a bit heavier, but very durable, and comforting in bigger water. Not sponsored or affiliated, but they''ve always been good to me and its nice to support domestic production...edg
Re: Paddles
Posted: Sat Jun 07, 2008 8:58 pm
by beereddy
I have been extremely happy with my Galasport. It has held up to alot of creeking in TN and banging down the cement ditch in Charlotte. It seems ok in big water, too. That being said it may break or be lost tomorrow, but so far so good.[/quote]
I agree!
Posted: Sat Jun 07, 2008 9:25 pm
by knu2xs
Most likely I am not a good example, but last year I broke a two Double Dutchs (blade on both) and two Mitchells (blade and neck). Before this, I was fed up with Galasports because they broke way too easy. About the longest lasting thing out there for me right now is a paddle out of Poland, GPower. This is what I am currently using.
Granted, it should be understood I train full time on the Charlotte course. River running puts a very different type of stress on a blade than slalom training on artificial whitewater.
For just everyday use, the best I've found is a well built wood paddle. I was never able to break my old Silvercreek, and I whaled on that paddle. It got me down some of the gnarliest creeks anywhere. There was more than one occasion where I was watching the whole paddle flex...A LOT, and never even so much as showed a stress fracture.
Now it is in the hands of a Venezuelan C1 racer who was here at Pan Am's. He broke two paddles in three days when he first got here. After getting his hands on that paddle, he didn't want to let it go.
For a general use recreational paddle, my next stick is going to come from
Pothole Paddles. A raft guide from the Chattooga lives just into South Carolina off of 76 and builds some of the best wood paddles I've seen anywhere. His craftsmanship is impeccable. Not only are they beautiful, as a paddler who paddles hard himself, he builds solid paddles which can be used hard.
