identify my boat
identify my boat
I acquired a whitewater canoe in good condition (thanks to David Nickerson, Jim Michaud, and Bill Reap for the complicated transport). I don't know what it is. It is a Mad River boat. Has Mad River decals and end plates. No serial number. Never had one. Royalex. Blackish/green exterior, olive drab interior. 13'2 length, about 3" of rocker, 31" maximum width, a little tubby in the middle. Paddles well (at least on the Fife Brook section of the Deerfield). Looks like a less-rockered, slightly longer, slightly wider Outrage X in a weird color. Any guesses?
Look under "Search Boats"...
Look under "Search boats" and see if any of the images look familiar. You can filter by OC1, etc... CHeck out Race and Rec, just in case it's miss-categorized (wouldn't be the first time...).
The two Mad River boats I've owned, both older, had the serial number stamped into the royalex close up under the gunwales - easily obscured by mildew and such. Might be even harder to see on a darkly colored hull? Pix would help!
I'd guess a Rampage
The Rampage was 13'-3 or 4" with about 4" of rocker. It carried it's volume almost to the ends...looked really tubby. Sounds more like what you might have. I tried to find a picture...maybe snap a digital from an old catalog...
Mike
Mike
Okay, I'll take some pix soon. Re-measured the boat. 13' even, bow and stern plates are the same as Outrage plates except they have a 1" thick plastic extension on the ends (thus my 13'2" measurement), and 29 1/2" maximum width. Definitely not Rampage. I don't know the Flashback, but the bottom isn't like a bowling ball. Pictures soon.
