Hi Chris, as you know I just bought a used Dagger Genesis.
It is an asymmetric boat and when I look at the saddle is fixed, I wonder if the boat has not been mounted upside down.
It's hard to say because I do not know which defined the meaning of this boat. (Front - Rear)
Currently, tip the boat is the closest faces the paddler and the widest point behind the position of the paddler. Regarding distance, saddle seems slightly backwards.
Do you know someone with a theory that applies to boats asymmetrical?
Do you have accurate distances on the best position of the seat in this boat?
Thank you!
Saddle position in a Dagger Genesis
