Remix question
jededmon
Remix question
Post by jededmon »
I've been thinking about converting a remix.... I'm 155lbs. Anyone have any thoughts on the 79 vs the 69 for my weight? Thanks
Jeff
Kelvin
Post by Kelvin »
Jeff,
I'm around the same weight and got rid of my 69 as it was too floaty! 79 would be MASSIVE on you!
Kelvin.
Pierre LaPaddelle
Post by Pierre LaPaddelle »
Hey Jeff
I'm an old OC-1er, who has recently decided to take up C-1ing.
I'm around 160#, and bought a converted Remix 79. Yes, it's way floaty, but as a noob used to an 11' Ocoee, I enjoyed it as a 'beginner boat' - a good transition to something better suited to my size.
It's been a great confidence builder, and super-solid in big pushy water. It's not a playboat! Now that I've built up some confidence, I'm looking for something smaller.
A buddy, on the other hand, coming from kayaking to C-1ing did the opposite -- being used to little kayaks, he converted a Small Burn to C-1. He's now shopping for something bigger.
(We're going to meet somewhere in the middle!)
Bottom line, I guess, is 'what's your previous experience and level of skill, and what kind of use are you going to put it to?' And -- if possible -- TRY before you BUY!
Many of the comments on this forum suggest looking at the recommended weight chart for kayak use, then choosing one size higher for C-1ing. Nothing's engraved in stone, methinks!
Good luck, and post when you have compiled some experience based on your choice. I'd be interested to hear your conclusions.
Rick
C'est l'aviron. . . !
marclamenace
Post by marclamenace »
I am 165lbs and has the 69. Always wondered about how the 79 would handle for me. But I love my boat. Floats me well for sure, not too much though for me liking. I also had the boat as my first C1 creek/river runner and like it.
If you look at the specs the 79 isn't much longer. More volume and a whole inch wider, so my guess is it would be a bit slower and more stable. My knees doesn't like so much the 6.5inches saddle I had to go down with for the 69 that's why I always wondered about the other size but oh well... wish we could all try as many boats as we could before to buy but lifa is though on C1ers. :-?
A friend and I converted Remixes - I'm about 220# and went w/ the 79, Josh is about your size and went w/the 69. I think we picked well. Unless you reallllly think you need a lot of extra volume (and a heavier boat) - i'd really think the 69 big enough.
markzak
Post by markzak »
I agree with all... I am about 185 lbs. and I paddle a 79, and while I wouldn't consider a 69 for myself, the remix has an advantage of added length, so it looks like a 69 would be perfect. The length I think gives you extra glide and punch, which I think makes for a good C1.
You are comfortably in the bottom third of the kayaker weight range of the 69 - 130#-240#. A common suggestion is to go "one size up" on conversions. I don't think that is necessary with this weight range (or the considerable overlap in the models...). Heck the next down says 110-200# and the next size up says 180-280#!
TheKrikkitWars
Post by TheKrikkitWars »
Kelvin wrote:Jeff,
Kelvin.
How is it that you can handle 160ish gallons of OC1 just fine, but a 69 gallon kaynoe is too big?
I've always found bigger to be better in canoeing... Though I guess I'm big enough to just about fit most large sizes adequately.
fez
Post by fez »
I have 138 pounds and am completely happy with the 69. Not to big at all.
imagine
shanebenedict
Post by shanebenedict »
I agree the 69 should be ideal as a C-1 for you.
Shane
C-Dawg
Remix 69
Post by C-Dawg »
I am 185 lbs, 6' 1" and paddle the 69, the 79 would be too big for me. I would like a more of a flat hull maybe like a Mystic. I had a WS Z which was stable but slow. I like the upfront volume of the Remix, turns well but I don't paddle enough anymore to handle the displacement like hull. Still miss my cuda max from the 80's.
C-ing is believing!
jededmon
Post by jededmon »
Thank you for all the input.... looks like I may be in the market for the 69 shortly.
Jeff
coloradopaddler
Post by coloradopaddler »
contrary to most of the other posts, i am very happy with my remix 79, and i weight about 170 lbs. i bought it from a kayaker that was certainly lighter than me. i bought mine to be a creeker and bob like a cork! here is a link to a few pics of me in mine.
http://www.mountainbuzz.com/forums/memb ... ms179.html
i guess it is all in what you want from the boat. i think the 79 is a very stable, very easy to roll, decent tracking, fast, good boat! i have a play boat, this is a bouyant fast hull. not trying to persuade your decision just trying to provide my personal perspective.
NedPoff
I am 165 and have paddled my son's 59 and it worked...
Post by NedPoff »
quite well. that said, I had a 69 hull given to me and have it set up. If you are ever in the DC area, I'd be glad to let you try them out. I think you are going to find the 79 to be quite massive for you, but try one if you can.
Ned
