Page 1 of 1
No crack on the prelude or l'edge
Posted: Thu Sep 22, 2011 6:23 pm
by Kris
If you don't want a crack behind your saddle, take out the saddle and round it like the shape of the bottom of your canoe.
Regards Kris
Posted: Thu Sep 22, 2011 7:45 pm
by truckeeboater
you would think that Esquif would do that for you...
Posted: Thu Sep 22, 2011 7:47 pm
by marclamenace
R U say'n their saddles doesn't fit in their boat so much that it creates tention somehow? You would think they carve them to fit do they nuts?
Posted: Thu Sep 22, 2011 7:57 pm
by Kris
In Belgium we cut the saddle so that it fits, So they(Esquif) make standard saddle, I make custom made saddles or we adjust the standard saddle.In the factory they can't fit out the saddle custom made.
Regards Kris
Posted: Thu Sep 22, 2011 9:12 pm
by Larry Horne
that must be some stout foam
Posted: Fri Sep 23, 2011 1:30 am
by Smurfwarrior
Posted: Fri Sep 23, 2011 1:08 pm
by KNeal
Hi, Kris. I am not sure what you were saying in your original post. What it looks like to me in the original post is that a crack develops behind the factory-installed saddle of Esquif boats. Can you be more clear what you mean with this "crack behind the saddle"?
Posted: Fri Sep 23, 2011 2:55 pm
by Kris
When you make the saddle round it will keep the shape of your boat and you don't get a flat section, so that it looks that you had a bump behind your saddle
Posted: Fri Sep 23, 2011 3:40 pm
by Shep
I think it may be worth doing, but the only broken PE hull I've seen did NOT crack under or right next to the saddle. I think there is not enough evidence to say that the saddle shape creates any significant stress risers in the hull. And to verbalize what I think Larry and Smurf are getting at, minicell foam will likely deform quite well during an impact. Heck, kayak manufacturers often put it under their seats, and they have lots more failure data by which to design their products.
