gunnels holes in wrong place
henryflipinger
Post by henryflipinger »
screwed up and drilled right side lash holes about 2" forward of the left side. so i decided to drill some other ones so the lashing would be straight, had i done it in the stern i would not have worried about. how does this look? the second rope is a dummy string filling the holes drill by the dummy. i could drill some more holes on the other side to match the screw up ones. i have taken forever getting this thing outfitted just so i can go throw it around on the rocks this weekend.
photo 1.JPG (33.32 KiB) Viewed 3821 times
photo 2.JPG (33.2 KiB) Viewed 3821 times
arhdc
Re: gunnels holes in wrong place
Post by arhdc »
I wouldn't worry about it.
I have spent too much time in the past obsessing over such things and in hindsight, once you get some river time on it and bang it around a bit you won't care one bit. It looks like a good job and is not going to be seen unless someone is looking really close.
~Aaron~
iRolled
BlackFly Canoes
Post by iRolled »
As long as it floats, right. Don't stress the little things.
Team Blackfly
AJ
Post by AJ »
No drinking or mind altering susbstances while working on outfitting!
It must bother you or you wouldn't have posted this. Why not add the same holes on the other side and make it symetrical?
cheajack
Post by cheajack »
You don't paddle esthetics
ELGOTTO
Post by ELGOTTO »
Why not tie a knot in the hole instead of looping cord from one hole to the other or leave the holes empty.
You can fill unused holes with thickened G-flex epoxy. Eric Nyre says that, over a number of years, exposure of the foam to water causes it to lose its elasticity. But you'll probably batter the boat to death before then.
henryflipinger
i am not messing with it. i am gluing the saddle in tonight and one more coat of tung oil and then we are going to go jump some rocks on friday at the nolichucky. ill post a finished pic when she is done. thanks all.
cheajack
Post by cheajack »
What time you puttin on?
TNbound
Post by TNbound »
If you hadn't called yourself out, I bet nobody would have noticed! As long as it will hold the bags in, you're good to go.
-Anthony
keez
Post by keez »
My boat's got a HUGE hole in the top.
Still floats OK when it's right-side up.
Happy paddling.
Todhunter
Ridge Spirit Outfitting
Post by Todhunter »
My bag cage lines are crooked. Never had anyone (but me) point it out. Who knows...you might start a trend....
Matt Todhunter
Post by Larry Horne »
if you look close enough, everything in canoes and kayaks is crooked.
