Page 1 of 1
Rolling an Option
Posted: Sun Jan 06, 2013 10:45 pm
by BobH
I have been paddling an Option for about two years now and my roll has been iffy. In whitewater I'm getting a little better than 60% of my rolls, in a pool closer to 95%. The problem seems to be at the very end of the roll. Yesterday Jordan Poffenberger looked at my form and couldn't see anything wrong but his father had a suggestion which makes a lot of sense.
Keeping the center of gravity as low as possible at the end of the roll is a good thing. Due to the design of the saddle it isn't possible to lay flat on the front air bag. A simple solution is to trim down the foam between the paddler's waist and the front thwart.
I'll let you know how it works
Re: Rolling an Option
Posted: Mon Jan 07, 2013 4:47 am
by Bob Wiggins
you know, that isnt actually a bad idea.... i would, however, recommend taking the airbags out before touching any of that foam with a knife.
Posted: Mon Jan 07, 2013 11:27 am
by PAC
Makes sense.... (cutting and knike)!
Particularlly with those of us with more "girth" in the middle!
Posted: Mon Jan 07, 2013 12:42 pm
by Big Al
Bob's all muscle there.
Big Al
Posted: Wed Jan 09, 2013 6:36 am
by Daddy-O
being a newb boater I offer up my words with all do caution and respect. I hear you on getting the boat set up just right for you. I found the Option to roll extremely well, and so would also consider scrutinizing my technique further.
I've noticed that if I'm struggling at the end of a roll it is "usually" from poor form in the beginning. This is assuming I'm not pinned or the like. On a recent float on FrenchBroad Sec.9 I was trying out a small c1 "thus working on my roll" when a fellow boater pointed out that I was initiating my hip snap too early, or too deep, in the water. I was sort of rolling sometimes, but not even close to what you might want if for example you were to "need" your roll. After working some more on this I find that a huge wind up, with my head almost surfacing, has been really snapping me upright quickly. The position is somewhat uncomfortable until you become accustomed to stretching that far, but until then the bigger a stretch the better. The brace at the end of the roll is more steadying than righting. Happy practicing, good luck.
-peace
Jason
