Dagger Aftershock Re-Outfit
Posted: Tue Aug 19, 2014 3:36 am
Just finishing up my latest outfitting project. I bought the girlfriend a Dagger Aftershock. She expressed an interest in trying an open boat a while back and has been eyeing my Spanish Fly. Easier to get another boat than make an adjustable bulkhead. The Aftershock seems to be a perfect boat for her 5'4" frame. Not as deep as the Fly, so easier for her to roll. And she's been paddling a ProZone for years, which has a surprisingly similar hull shape. She didn't want foot pegs, so the plan was a shallow bulkhead and thigh straps.
Started with about 5 cubic feet of foam. Those blocks are 1' x 3'. Three 4", and four 2" pieces. And yes I used nearly every piece of it plus a piece of 1" I had leftover from last project. I might add more to the sidewalls later when she's more comfortable with the boat.
My outfitting philosophy is like this...
1 gallon of water = about 8 lbs
5 cubic feet of foam = about 10 lbs
5 cubic feet of water = about 310 lbs
Foam = not water
Not water = an enjoyable pump/dump free paddling experience.
All my favorite tools. The wire wheel is great for removing large amounts of foam, FAST. Great for roughing in thigh hooks, then finish with hacksaw blade scraped sideways to smooth flat. Speaking of thigh hooks... Will someone PLEASE invent a spray in outfitting. Imagine getting a boat with about 80% of a bulkhead, cover your legs in plastic, sit in the boat, spray in foam, let harden, get out, trim smooth, Done.
New handles that you can actually grab!
New thwarts. You might be thinking that they are crooked, but they're as even as it gets. The originals were all out of whack. Also drilled new holes a reasonable distance from the edge of the plastic.
3" of sidewall foam, 1" knee foam, and foot wedges. I make the foot wedges with a 2"x12"x5" foam cut on an angle.
Saddle in progress. OK, I know that this looks like a ridiculous amount of saddle, but the thwarts on the Aftershock are WAY too far out for a bulkhead. If I could have, I would have moved both thwarts towards center by about 4". Oh well, work with what you've got. Saddle is 8" wide, 36" long, 14" tall.
I'm going to try and get away with one 3" transfer tube. That's about all that I have in my Spanish Fly and it works for me. Thigh straps are anchored to it. Yeah, sch 40 is overkill, but that's what was lying around.
Foam Finished. Last step is to install outer anchor points for thigh straps. I should get that done tomorrow.
Here's a question... I'd really like to get this rear airbag to come forward and fill more of the foot space, but I'm out of ideas on how I can make that happen without moving the thwart and trimming off some saddle, which is not really an option. The thwart tabs are where they are. Anyone have any ideas?
Foam = not water
