L'Edge Superlight Outfitting
Jon
Post by Jon » Fri Dec 21, 2018 11:55 pm
Got one. Really like it.
The tube to transfer water from side to side through the bulkhead is very small. 1.25" inside diameter
As I recall, a suggested mod in the old days was to replace that with a 4 or 5" square chunk of plastic eavestrough downpipe. Any comments or suggestions? I assume the smaller pipe keeps the water from sloshing side to side and perhaps makes the boat more stable with water in it? But, when I pick it up to empty out, I notice how slow to drain, the high side of the boat is.
The small transfer tube is also a good 1.25" above the inside of the hull, so there is a fair bit of water that must make the trip around the ends of the bulkhead to get to the otherside. Does the boat require this cushion of foam to strengthen/protect the hull?
As a winter project (cause it involves ripping out the saddle/bulkhead) any suggestions as to replacing the tiny tube, with what, and where?
Thanks and Merry Christmas
Wendy
Re: L'Edge Superlight Outfitting
Post by Wendy » Sat Dec 22, 2018 1:43 am
I put a 3 inch round tube in that location. It takes time with the saddle in place but doable. I use a knife. Once 3 inches of foam has been carved there is a Dewalt adapter you can buy to attach a hole saw for right angle use.
pmp
Post by pmp » Tue Feb 05, 2019 1:45 am
I always meant to do that... but didn't. Not sure if I like the idea of different flex rate under the wall of a square piece of plastic. I did remove the plastic pipe that came in the hole, since there is no reason to need that in there.
bubblestreet.ca
theracane.ca
