Long Boating
Kelly-Rand
Long Boating
Post by Kelly-Rand » Wed Sep 11, 2019 1:08 am
This past August I tried something different on one of my favorite rivers to prolong my river enjoyment, which was to take my 16' tandem down instead of a C1. The Dead river in Maine is a 15 mile run that has always challenged my kneeling stamina and this year I decided I wanted to be able to smile during the last mile of flat water. In the spring I had taken my Millbrook AC/DC down the South Branch of the Potomac through Petersburg WV. on an annual camping trip and discovered that this boat with a 100#'s of gear and paddler handled big wave trains really well when the paddler was a few feet behind centerline of the boat.
The Dead is a 15 mile run with long rapids punctuated with short stretches of still water. A good number of the rapids culminate in large standing waves interspersed with holes and a few have large standing waves for their length. There are two rapids of notable difficulty because of the lines needed to avoid large holes, Haydens and Poplar Falls. The former is boat scout-able but the latter you need to know where you want to be before you turn the corner as there is a large hole midway down that spans half the center left of the river bed, going right of center after you pass the guard rocks at the top of the corner is the easiest route.
The biggest difficulty paddling long boat style is determining how much effort or reduction of is required to make steering corrections as the shallow draft of such a long boat causes it to be bounced around a bit. The good thing about this is that it tends to ride over even the largest wave trains with little water gain. I seemed to put a lot of effort into turning the boat in the beginning but as the day progressed I found I could make smaller corrections by timing them with where I was on the wave. At the end of the run I was still comfortable in the boat, not kneeling at my C1 saddle height and being able to change my position enabled me to avoid the crying pain I usually experience half way through this run.
Long boating is not as fun as C1ing in a nimble boat that can catch eddies on the fly and allow you to criss cross the river eddy to eddy but it is satisfying to not have to give up a river.
Jim KR
"with single blade in hand
a C-1 I will stand"
Roy
Re: Long Boating
Post by Roy » Sun Sep 22, 2019 2:12 am
On a number of occasions, for a number of different reasons, I have paddled an Old Town Tripper solo in whitewater. I've always found it more fun than one would expect. Especially, unloaded...but, still, pretty fun with gear. Those boats draw so little water, empty and solo, they all kinds of spin.
For all-day-in-the-boat runs in, say, a Cascade, I take a chunk of minicel and sit on it (on top of my normal 7 3/4" high seat) in the easy sections. Of course, there is always the risk of washing into something one would rather not paddle in that configuration. But, I find the periodic "vacations" from being down on my seat helpful.
Roy
Kelly-Rand
Re: Long Boating
Post by Kelly-Rand » Sun Sep 22, 2019 12:11 pm
Roy,
My first time on the Dead in 2000 I was guided by someone paddling long boat through Poplar running the left side line. I've thought of bringing a booster block on the Dead but the problem is I can't remember which rapids would be suitable or there order to drop down to the stable seat height. Thigh straps are useless above a certain seat height 7"-8", which I'm at the limit now, at least for more than one roll attempt. My low brace has gotten much better though since I've raised the saddles.
Jim KR
a C-1 I will stand"
Roy
Re: Long Boating
Post by Roy » Sun Sep 22, 2019 5:27 pm
Jim,
I have paddled the Dead plenty of times, and I, too, can't remember what's up next on that river.
A number of my C-1s have had machines (foam, aluminum, or glass), and getting back down into the machines, after removing the add-a-block may be quicker than with straps. Of course, machines are next to worthless when one is up off the seat.
I used to paddle OC1 quite a bit while using a 10" thwart seat. I don't recall any issues with straps not working. I had hip, toe, and knee blocks in those boats. They were roll-able.
Roy
Peter K.
Re: Long Boating
Post by Peter K. » Tue Oct 01, 2019 8:58 pm
Long boating seems to have a significant following in the UK where they call it "traditional" canoeing. Seems more popular in the south where the gradients aren't too steep.
