CBoats.net - C1 B1!
No Flash
Check out
It is currently Sat Aug 18, 2018 1:55 pm
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: airbag lacing
PostPosted: Sat Jul 30, 2016 4:30 pm
Offline
I have a Wenonah Solo Plus made with Tuf-weave. (Their website says Tuf-weave is a combination of polyester and fiberglass). The gunwales are aluminum.
I paddle the boat solo, and I would like to add lacing for extra flotation. I've been reading on Cboats that it's pretty standard to drill through the hull. Is that just for Royalex boats? Will it work with this Tuf-weave stuff? Any special considerations for drilling through fiberglass?
Top
 Profile
 Post subject: Re: airbag lacing
PostPosted: Sun Jul 31, 2016 4:23 am
Offline
I've seen holes drilled through the hull of composite boats for airbag lacing.
_________________
http://www.JohnstonPursuits.ca
Top
 Profile
PostPosted: Sun Jul 31, 2016 2:40 pm
Offline
I have a Tuff-weave boat, with drilled lacing holes, sitting in my yard right now. No problems or issues.
I have also drilled lots of other composite hulls for bags.
Roy
Top
 Profile
PostPosted: Mon Aug 01, 2016 5:53 pm
Offline
Deburr the holes so that the edges don't abrade the cords.
_________________
Top
 Profile
PostPosted: Mon Aug 01, 2016 11:32 pm
Offline
My Echoee has the cages drilled through the hull with grommets to protect the string.
Top
 Profile
PostPosted: Tue Aug 02, 2016 3:48 pm
Offline
For a clean hole when drilling composites (or most anything for that matter), clamp a scrap piece of wood on the back side. That prevents tear out, and allows the bit to make a clean cut as it exits the hole.
But looking at the photo of your boat, drilling through the flanges of your aluminum gunwales is an option. That would get the holes up nice and high, and there would be no concerns about damaging the composite, because both sides of it are protected by aluminum. The holes you will be drilling are small, and spaced apart, so I would not be concerned about them weakening the gunwale. You're just not removing enough aluminum to have that kind of impact.
If you do drill through the aluminum, as a second step use a chamfer bit on both sides to remove the sharp corners of aluminum. This is really quick and easy, and chamfer bits are cheap and readily available (if you don't already have one).
Top
 Profile
PostPosted: Tue Aug 02, 2016 5:07 pm
Offline
I agree with NickParker posting.
_________________
Top
 Profile
PostPosted: Wed Aug 03, 2016 7:58 am
Offline
You can also glue webbing loops to the hull:
http://www.canadierforum.de/t9050f4-Pro ... ten-1.html
Top
 Profile
PostPosted: Wed Aug 03, 2016 11:50 am
Offline
I did something like that to my boats. I would check the glue adhesion to the hull first though.
_________________
Top
 Profile
PostPosted: Thu Aug 04, 2016 2:20 pm
Offline
Thanks for the input. It's good to know that it's safe to drill.
I also like the idea of gluing webbing loops or something similar. Is there a piece of hardware made for that purpose?
Top
 Profile
PostPosted: Fri Aug 05, 2016 4:43 pm
Offline
I'd just drill and be done with it. 30 min and you re finished.
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 14 guests
Search for:
