CBoats.net - C1 B1!
Check out
It is currently Wed May 23, 2018 4:29 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
PostPosted: Fri Oct 14, 2016 5:56 am
Offline
What's the best way that everyone's found for removing the skin from full thicknesses of minicell? I have an orbital sander and disk grinder, but I think that I ended up going at it with a sanding block last time. I'm just building up a pedestal, but I might buy tools to make the next projects (ie, bulkheads) easier.
Top
 Profile
PostPosted: Fri Oct 14, 2016 11:02 am
Offline
I've used an electric carving knife. It's not a fun job. Now I buy foam without the skin.
_________________
Mike W.
http://waterdata.usgs.gov/nc/nwis/uv?dd ... o=02080500
Top
 Profile
PostPosted: Fri Oct 14, 2016 2:11 pm
Offline
I have used fine Shurform tool. They can make a thin cut and leave a uniform surface for gluing. I like the long (12 inch ) ones for a better grip and control.
Top
 Profile
PostPosted: Fri Oct 14, 2016 3:10 pm
Offline
I concur on the Surform. I prefer one like this as it lets you get more pressure to break through the skin.
http://mobileimages.lowes.com/product/c ... 211153.jpg
Top
 Profile
PostPosted: Fri Oct 14, 2016 5:19 pm
Offline
I use a large bandsaw with a fence to make a consistent cut. Much easier than other methods. If you don't have one, check out a local woodworking shop. for a couple bucks, they will cut it for you.
Top
 Profile
PostPosted: Fri Oct 14, 2016 6:54 pm
Offline
Mike W. wrote:
. . . Now I buy foam without the skin. . .
Not sure why you would buy foam with the skin on in the first place. Rare times I've bought small chunks from our canoe dealer, and I've never been offered pieces with skin on. Nor would I accept them if they were offered.
More often, I've bought foam by the complete sheet ('bun') from the supplier, and they cut the skins off, as well as slice the foam into various thicknesses, for no extra charge.
I take the skins, usually around 1/8" thick, and glue them onto high-wear areas (knee blocks, saddles) with the shiny side out, to prevent the usual wear-and-tear of the foam. Waste not, . . .
Rick
_________________
C'est l'aviron. . . !
Top
 Profile
PostPosted: Sat Oct 15, 2016 11:30 pm
Offline
Orbital sander with 60 grit is what I use. I have air and a Dynabrade though, so that makes it easier.
Top
 Profile
PostPosted: Mon Oct 17, 2016 2:57 am
Offline
+1 bandsaw. If not, then Surform.
Top
 Profile
PostPosted: Mon Oct 17, 2016 3:13 am
Offline
Thanks, all. I've had this stuff for a while, but I think it was the only full thickness black foam that I could find online. If anyone has a source, I'd like to hear it.
I don't have access to a bandsaw set up for resawing, so I'll probably just go with a belt sander. I may try a power planer on a minimal cut first to see if it can cut without digging in.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 10 guests
Search for:
cron
