CBoats.net - C1 B1!
Check out
It is currently Sat Aug 18, 2018 1:53 pm
Post new topic Reply to topic  [ 15 posts ]
Author Message
PostPosted: Tue Feb 20, 2018 5:42 pm
Offline
Hi all y'all!
I ordered an Octane 91. Looking forward to giving this OC1 thing a try! I have a little bit of experience in moving water. Canoe tripping, IK, rafting both paddle and oar boats, mckenzie boats, K1, C1; not real deep into anything particular but a little bit of each. I have more training in swiftwater rescue than actually recreating on swift water. So I'm looking for some education opportunies with regard to OC1. I live about an hour north of Duluth, MN. I can't make ALF this year but its already on my calendar for next year!
Top
 Profile
PostPosted: Wed Feb 21, 2018 12:17 pm
Offline
Another OC Dan...seems like many canoeists around MN are either Dave or Dan. Congrats on the new boat. Glad to have another open boater around.
One option for instruction: https://rapidsriders.org/canoeu
I think most or all of the cost goes to food and lodging, maybe some to ACA membership, See you on the water
Top
 Profile
PostPosted: Wed Feb 21, 2018 1:04 pm
Offline
Yeah I stumbled across the rapid riders in my search for information on the Octane. I'm interested but I'm not sure if they will waive the pool night requirement. It'd be about a 4 hour drive for me, one way.
Top
 Profile
PostPosted: Sat Feb 24, 2018 1:33 pm
Offline
Surely they would. Also check FB for the group Midwest Whitewater Canoeing.
Top
 Profile
PostPosted: Sat Feb 24, 2018 5:16 pm
Offline
Octane 91 arrived Thursday.
Any advice on fitting the bulk head? I started with working the knees, then took about an inch out of the back rest. My nuts are still about 3 inches from the front vertical of the saddle and I can't quite sit on the saddle yet. I feel like my knees could go in further but they won't. I feel pressure on the top of my thighs and inside of knees. Did some more trimming in those areas but didn't seem to really allow me to get further into the saddle. I'm 6-2 220lbs, 34" inseam.
Top
 Profile
PostPosted: Sun Feb 25, 2018 1:43 pm
Offline
Use a bread knife and rasp in the knee hooks. Be careful about taking too much off the backrest. It’s easier but will move your balance point to stern heavy. Work it little by little. Smooth the foam with fine sandpaper
Top
 Profile
PostPosted: Mon Feb 26, 2018 4:18 pm
Offline
Ditto on carving any more out of the back--what you did was probably enough. Keep sitting in the canoe, feeling where there is pressure on your legs that is keeping you from sinking in all the way, and trimming the foam accordingly. Eventually you'll get there--a perfect custom fit.
Top
 Profile
PostPosted: Tue Feb 27, 2018 4:24 am
Offline
Worked on it for a few more hours tonight. On the bright side, I'm getting pretty good at getting in and out of it. I have it to the point it's reasonably comfortable in jeans and street shoes. I'll probably find a pool and try it like this for a bit before I hack much more out. I cut out at least a shopping bag worth of foam. I can snap my hips and the boat is pretty well stuck to me.
Top
 Profile
PostPosted: Tue Feb 27, 2018 9:53 pm
Offline
good stuff dan,
add some hip pads, they are more like thigh pads and you should be real snug.
https://youtu.be/SfORNFa3pxw
good luck,
d
Top
 Profile
PostPosted: Thu Mar 01, 2018 1:56 pm
Offline
Yeah I stumbled across that video yesterday. Anyone know where to order minicell foam blocks from?
Top
 Profile
PostPosted: Thu Mar 01, 2018 2:32 pm
Offline
https://www.mohawkcanoes.com/collections/foam-parts
lot'sa foam on the ol' interwebs
_________________
OC1 spoken here.
Top
 Profile
PostPosted: Sat Mar 03, 2018 12:26 pm
Offline
or check our Links section (which admitted hasn't been gone through in ages...)...
http://kayakoutfitting.com (don't hold their name against them... Eric Zitzow is great to deal with and an awesome squirt boater...even if he does use 2 blades...).
_________________
Top
 Profile
PostPosted: Wed Mar 07, 2018 8:06 pm
Offline
I ended up ordering some 12"x12" 3" thick blocks from NRS, added a new throw rope to the order to make the minimium. Need to source some contact cement locally yet.
Top
 Profile
PostPosted: Wed Mar 07, 2018 8:42 pm
Offline
any hardware store worth a lick will have contact cement.
d
Top
 Profile
PostPosted: Thu Mar 08, 2018 1:59 am
Offline
I'd be happy to work with you on paddling tech - sounds like you've got the outfitting started at this point. I don't know if anyone is ever done outfitting, seems like I keep lowering my saddles and creating a more secure set up. I paddled OC for a long time, but moved to C1, and then got into slalom...
_________________
Used to paddle, currently live in desert...
Top
 Profile
Who is online
Users browsing this forum: No registered users and 17 guests
Search for:
