CBoats.net - C1 B1!
Check out
It is currently Wed May 23, 2018 6:56 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: C1 Conversion
PostPosted: Sat Mar 17, 2018 4:22 pm
Offline
Has anyone had experience with the C! conversion kit from Jackson?
1. The pictures suggest that you need a release a rope on the backband to wet exit. This seems like more than I might want to worry about in a wet exit. Any experience?
2. I am intersted in a Jackson Zen.
If it were a kayak, then I would order a medium. Is there a reason to go up a size because my center of gravity is higher.
Mort
Raleigh NC
_________________
Ra;eigh, NC
Top
 Profile
 Post subject: Re: C1 Conversion
PostPosted: Wed Mar 21, 2018 12:43 am
Offline
Call Bernie at whitewater warehouse , he can tell you all about the jackson/ c1 kit since he sells and uses them
No , wet exits are easy from this kit.
I would pick my boat size based on paddler weight only, not on k1 or c1 use.
Cheers
Top
 Profile
Who is online
Users browsing this forum: No registered users and 11 guests
Search for:
cron
