CBoats.net - C1 B1!
Check out
It is currently Mon Dec 18, 2017 8:40 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Tue Oct 31, 2017 6:05 pm
Offline
Hello Everyone,
I am considering an Idol dry suit and am curious about any feedback positive/negative. Does the switch zip cover get caught momentarily on gunwales in the event of a swim resulting in premature zipper problems? Has anyone punctured/torn their suit on the switch zip screw? Thanks You..
Cheers,
Will
Top
 Profile
PostPosted: Thu Nov 02, 2017 2:53 am
Offline
I have had one for several months. The hard part is aligning the zipper initially to get it started. Once started it easily closes. To store the suit I run the "cover" back around the zipper and place it on the screw. The zipper has not gotten in the way, nor caught on the gunnels.
Top
 Profile
PostPosted: Tue Nov 07, 2017 10:09 pm
Offline
Thank you for the info on your suit. Spoke to a couple pro-boaters and several in the "industry". All said the icon is awesome once you get the zipper dialed in. There were some other minor quips mentioned but when I asked if they were chucking their meridian suits to get an icon, 98% said no. At the end of the day the icon is newer tech with completely different zipper construction and placement, all comments I got were comparisons based on experiences with meridian suits. If someone has never owned a dry suit before, they would not know the difference. I went with another meridian suit.
Cheers!
Top
 Profile
PostPosted: Tue Dec 05, 2017 9:54 am
Offline
pretty happy with mine
with my old meridian the zippers in the front and at the butt were bothering me a bit (restricting my range of motion), which is solved pretty well by the idol
_________________
it's gettin hot
I MAKE THE WATER BURN
purple orange flames
blaze where I put my paddle
Top
 Profile
Who is online
Users browsing this forum: No registered users and 9 guests
Search for:
© 2017 by CBoats.net - all rights reserved. Materials found on this website can only be used for personal use.
