CBoats.net - C1 B1!
Check out
It is currently Sat Jul 21, 2018 9:33 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Fri Jun 29, 2018 4:49 pm
Offline
I'm replacing the wood on a friend's Ocoee, and was wondering if Dagger steam bent the original gunwales?
Top
 Profile
PostPosted: Mon Jul 02, 2018 11:28 pm
Offline
I don't know, but I'd suggest you do it. No springback to deform the hull and much easier to install.
Bill
Top
 Profile
PostPosted: Tue Jul 03, 2018 12:14 am
Offline
When taking off the old wood I was a bit surprised to find that Dagger used some type of adhesive to bond the outwales to the hull. The adhesive had completely failed, so removing the wood wasn't a problem. They also edge glued the decks to the inwales. That still had a little bond to it, but it was easily separated with a utility knife.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 10 guests
Search for:
