CBoats.net - C1 B1!
Check out
It is currently Tue Aug 21, 2018 1:31 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Fri Jul 20, 2018 9:48 pm
Offline
Anyone know where to buy the gray hard-plastic narrow strip D-rings that you glue down with epoxy? They make great tie-downs in tripping canoes. I've been searching the web for them and striking out.
Top
 Profile
PostPosted: Sat Jul 21, 2018 1:34 pm
Offline
I only use the metal d-ring part and will let you know if I can find the hard plastic pieces. Mine were made by Voyageur (Mad River Canoe's accessory company). I don't know what happened to Voyageur when MRC was sold to Wilderness Systems and left Vermont. The was a long time ago.
Top
 Profile
PostPosted: Sun Jul 22, 2018 1:27 am
Offline
Try Jendapaddlesports
Top
 Profile
PostPosted: Sun Jul 22, 2018 4:00 pm
Offline
SCORE! I spent 1.5 hours searching on the web for these before posting and struck out. Jenda may be the world's last source of these. So thanks so much.
Top
 Profile
PostPosted: Mon Jul 23, 2018 1:55 am
Offline
I'm surprised Strapworks didn't have what you need... they always seem to have far more than I knew existed when it comes to such things!
https://www.strapworks.com/default.asp
_________________
Top
 Profile
PostPosted: Sat Aug 04, 2018 3:59 am
Offline
Western Canoeing and Kayaking, in Abbotsford, BC, used to stock them. Give them a buzz -- they prob'ly have some on the back shelves. They also (used to) stock the 2-part adhesive kits which work well with the plastic bases.
When you install them, I find it works well to drill small holes in the bases, so the adhesive gooshes up through the holes. It makes for a more permanent installation.
Rick
_________________
C'est l'aviron. . . !
Top
 Profile
Who is online
Users browsing this forum: No registered users and 25 guests
Search for:
