Finally on the prowl for a good starter/upgrade WW OC-1
I think I'm starting to hit a wall with my wide, stable ol' Mohawk Challenger. I can get it into and out of eddys on our class II local river just fine, surf, ferry, block and avoid the strainers, sunken engine blocks 'n rebar, etc., but I've come to the realization that my braces are weak. This is really limiting how aggressive I am...I still haven't fallen out of the d@mned thing! I'm thinking learning to roll will dramatically help this, but as much as I love it, the Challenger ain't the boat to learn that in. It's a fun boat, but maneuvering it is kind of like driving a Ford LTD Brougham in deep winter slush.
I've been in my boat, a Bell Yellowstone, a Dagger Rival and an Ovation. The Yellowstone was more limber and faster than my Challenger, but that's about it...it's an easy river/lake boat. The Ovation felt like a plastic wash-tub, but I really took to the Rival (part of a OC-1 river class I took a while back). It felt loose for the first 10 minutes or so, but for the remainder of the class, felt limber, responsive and had good speed/glide. I had a real blast in it.
I weigh 160 lbs and most of my height is in my legs, not torso. Given my budget is small and used Rivals don't come up very often, what other (used) designs out there share similar attributes? What should I keep my eyes open for? Where do Probes and Outrages fit in the spectrum with the Rival?
Phreon
Phreon
- marclamenace
One suggestion: try as many as you can!
Many suggestions:
prodigy
viper
rodeo
spark
prelude
Kaz is right, finding a used rival shoudn't be too hard if you look on this forum and other places... An old encore or skeeter would be though.
Have fun on the water!
Many suggestions:
prodigy
viper
rodeo
spark
prelude
- Dooleyoc-1
I'd try a slightly hotter design since you're looking for more. Go for a Viper 11, Ocoee or Spark.
You will have a learning curve of about a month if you go every weekend. After that you will never look back. You can do a lot more and enjoy lots of small river features in these boats. It will be fun.
Because of your size/weight, you have a lot of choices in canoes. The thing to ask yourself is whether you're looking for a river runner, like a Rival, or a boat that offers more interesting play opportunities. The Prodigy for instance is going to be a lot like the Rival. It's going to have good acceleration and glide. A boat like an Ocoee gives up some speed, but gives you more edge and control. A smaller boat like an Prelude adds more nimbleness and responsiveness, but also requires more precision and balance from you. So decide what style of paddling you want to do primarily and then try boats that fit that style.
Speed/glide is a high priority. Most of my paddling will be on rivers within day trip diststance and most of them have sections of slow, tedious water.
"Soft" primary stability has never bugged me in kayaks or canoes, but I do value firm secondary. If I went for anything with an edge, I think I'd still want to stay on the mild side. I have to be pragmatic about this; I'll probably never have enough time as I'd like on the water to get really good, so I need that elusive boat that is somewhat forgiving of stupid mistakes but has room to grow. If I can progress into a solid Class III+ paddler, anything beyond that will be sweet, sweet gravy (it's a bad analogy, I know. Work with me). I like the idea of a playful boat that can make the most of the small features on our "squirrelly water" local rivers (from all the engine blocks, tractor parts and I-beams dumped in 'em deflecting current in strange ways*), but more so, I don't want a slug.
The Rival seemed fun, but I really haven't had a chance to try many other boats to really know. It doesn't seem like there are many OC-1 boaters in the Cincy area and the paddle shops around here all cater to kayakers.
Phreon
*Google "Fernald Uranium Plant" and you'll know the exact section of the Great Miami we run; you can't find a section of the river closer to that environmental catastrophe.
Phreon
Yes, big picture, personal preferences aside, I'd put the Outrage, Rival and Probe 12 generally in the same category. Prodigy & Nitro could suit similar paddlers too.
As mentioned, you have lots of options at your weight, and it may be worth trying a Spark to get a livelier version of the qualities you like in an Rival/Outrage.
PY.
PY.
