Pumps
T-50, Smurf & Richard Guinn
Hi Smurf, I fell asleep at the keyboard. Linda says I've got square eyes.
T-50 is on and you are invited, accommodation in Vancouver provided. We all would look forward to seeing you and it gives us a chance to pay back for all the pay forward you have done on West Fest.
A fly in is easy but if you want to do a road trip I have parking. Of course you are invited anytime. PM or email on the way.
Thanks for the loanout of the light L'Edge. The earlier heavier model didn't really work for me but the lighter one is a different cat all together, IMHO. I liked it.
Richard Guin, hello if you are looking. Hope the car transmission thing worked out, 2nd time lucky? Vancouver paddlers are paddling road warriors but you win the prize with your 3 day one way epic, we were impressed.
It was good to meet you and put a face behind Mohawk after years of paddling the product. I enjoyed the run down the Payette Canyon with you, trying to pick apart your lines and I can't believe I blew away the offer to paddle your boat. Less thinking, more impulse.
Better yet, I would have seen you in a kevlar V11.
e
T 50
http://www3.telus.net/~soloboat" onclick="window.open(this.href);return false;
https://vimeo.com/47469873" onclick="window.open(this.href);return false;
(Event is on Sept 14-15 in 2013. I'll reload the correct video date shortly)
e
T 50
Re: Pumps
"Take a dump, not a pump!"--a slogan for anti-pump paddlers?
- FullGnarlzOC
Re: Pumps
been going with - no pumps. just dumps
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
Re: Pumps
That's more concise. Should fit well on a t-shirt.
Re: Pumps
gettin' too old to jump-n-dump, so i sits on my rump and turns on me pump.
- FullGnarlzOC
Re: Pumps
Re: Pumps
how fast is a pump?
I have never used one so far, and never installed one cause I always thought that if I need it, it's not quick enough to empty the boat. In a regular situation I can eddy in and dump. When I need help is when the boat is full and I have no chance to get to shore, and I've now reached the rivers where running it full is not a good idea anymore
imagine following situation: a 320 feet long class 4-5 big volume rapid with five big stoppers in it, steep walls, no eddy, absolutely no chance to run a dry line...I would have been full to the max after the first stopper and would have swam in the second at the latest with swimming bein possibly lethal at that point
I walked it.
Would a pump be fast enough to keep the boat manoeuverable so it would have enabled me to run that rapid?
I walked it.
it's gettin hot
I MAKE THE WATER BURN
purple orange flames
blaze where I put my paddle
Re: Pumps
pumps are for conveinence. to keep you dry in big water you need multiple pumps and thats getting silly. i did see a video of a 4 pumper though. it comes down to volume. how much water does your boat hold when running it? my boat holds 5 minutes worth at 1200gph.
Re: Pumps
I have posted before about a story where a pump saved my boat from going further down stream, but Harry is right, they are not fast. A good rule of thumb is that pumps might be able to keep up with the water coming in while you are surfing.
Shep
Shep
- FullGnarlzOC
Re: Pumps
if you paddle with a pump , you might as well wear nose plugs
Re: Pumps
young dinosoarass you need to get into a birch bark canoe and carve out your own paddle...just sayin'.
- Attachments
- auto bilge.jpg (41.46 KiB) Viewed 6640 times
Re: Pumps
A pump helps only for convenience. In a very small canoe with no space to use a bailer the only choice is to stop and dump. Or outfit the canoe so that when full it can still be maneuvered reasonably. I think that with Insolence's scenario a pump would not be fast enough to make the needed difference so outfitting is the only other reasonable choice
