savage skreem
Re: savage skreem
did i mention i am 6'4" 230# i fill the cockpit front to back. try folding a sasquatch into a kayak? footrest out floatation in. thigh straps back a bit,will do. thanks guys fir the advice.
Re: savage skreem
post the videos
Re: savage skreem
i got my saddle as low as i can go. this is about as good as this set up is going to get for me.
Re: savage skreem
That's going to be a tippy ride and it doesn't look terribly comfortable at this point. Somewhere around here there should be pictures posted once upon a time by a guy who posted as SpaceCanoe who took a not quite big enough boat (a Dagger Medieval?) and with a combination of heat and pressure (hot water, jacks, lumber?) he enlarged the cockpit. If you don't have the option of looking for a bigger boat, you might take that tack.
It will be a lot easier to deal with a tippy boat if you are comfy. Learning to paddle a tippy boat can make you a better paddler and, if nothing else, make your open boat feel massively stable when you hop back into it.
Re: savage skreem
Unless it's just going to be a pool session boat I think it's safe to say you chose the wrong hull. The trim's going to be awful and you're going to have stability issues.
You need a wide boat (26" or more) and a cockpit large enough to get far enough forward for proper trim.
Re: savage skreem
I've got a pristine H3 hull I'll trade you if you haven't drilled too many holes in that thing yet.
Re: savage skreem
have not drilled any holes in her,used factory hole to add my outfitting. i need to a least get wet in this puppy before i make up my mind what to do with her.
Re: savage skreem
wow. if it's a 255 that's a great hull to convert.cheajack wrote:I've got a pristine H3 hull I'll trade you if you haven't drilled too many holes in that thing yet.
Re: savage skreem
HH-you would fit MUCH better in the h3. the cockpit is higher and wider for yer legs to fit under..
Re: savage skreem
I really want to see this
Did you fixed up that broken paddle? a 60"er will be a lil tall for this boat.
Re: savage skreem
Yep. H3/255
Re: savage skreem
thanks everyone for all the advice. its finished?
Re: savage skreem
Spartan. I like it.
