Canoe for the Grand Canyon
Re: Canoe for the Grand Canyon
Hi, just came accross this thread looking for something else, as you do!
I rented the Moenkopi Whitesell for my trip last May, there is some discussion about my trip over on SOTP Forum.
The boat is obviously quite old but seemed pretty well spot on to me, it has even been fine tuned to deal with the afternoon head wind in the canyon
My swim count is in the thread, I think it was 9 paddling downriver (one of those on flat water) and one surfing a wave - I still have no OC1 roll!
Most rapids are easy because the essential move is at the top, in fact you often set up on the flat above to miss the problem feature, but as noted it is the chaos below that makes it hard work. There are a few trickier rapids depending on recent changes and levels - I couldn't visualize a line I had any confidence of making on Upset or Lava so portaged and lined them.
If you rent the Moenkopi boat I'd advise taking spare anchors and glue with you, a couple pulled off on me and there was sand in the glue suggesting poor quality field repairs in the past. I forgot to take glue and the rafters didn't have the right stuff so my repairs whilst properly cleaned up, might not last either.
Seriously, apart from needing some maintenance the boat is ideal - I was virtually an OC1 novice when we launched (owned an Ocoee for 5 years, paddled it once on grade 2 and spent some time trying to roll it, unsuccessfully), but found the Whitesell very easy to get used to and quite forgiving. Sometimes I wish I had one here instead of my Ocoee!
Jim
Jim
you want to buy one? I have a mint condition Whitesell stored indoors in Richmond VA. Still has the Whitesell airbags
$1300.00
$1300.00
I paddled a Caption with 2 pumps & 2 spare batteries stashed in a support raft. I thought it was the perfect boat & swam only 2x between Lee's & Diamond. My roll sucks too, so it really wasn't an option. It was a late July trip, so the swims were pretty sweet since they were at the bottom of drops. The runouts will get you if you aren't paying attention. Don't gloat until you are on shore. Have fun, it was the most fun I have ever had for 16 straight days paddling a canoe. I have found it more fun to row & drink beer, though.
George
George
The Devil is in the details...
since it is a 16 day trip in a canoe in a mix of flats and big water:
How many used straight pedestal rigs with the weight on the knees and in thigh straps?
who used a traditional system seat with the weight on the butt?
or... hybrid versions?
I'm lucky, my knees can do 7 days straight in a pedestal system on MFS or Deso Canyon
but luck is fickle. How did 16 days work out on the Grand, whatever the boat?
And who hitched an occasional ride on a raft for a stretch out?
C-1's need not reply.
- Jim Michaud
Last year I paddled the entire 280 miles in a C-1 Hahn. I've C-1ed, C-2ed or OC-1ed the Grand over 20 times (mostly OC-1) and never, ever hitched a ride. I just paddle ahead of the rafts a ways then get out and walk up and down a beach to get circulation back into my feet until the rafts catch up. Tying all the rafts together and motoring out to Lake Mead doesn't count as hitching a ride.
I don't care to OC-1 the Grand any more because it's much harder to fight heavy headwinds in an OC-1 than in a raft. It's hard enough to paddle against the wind but the damned wind keeps turning the canoe sideways.
By the way, I'm a 75 year old geezer.
Geezer knees
It's good to have someone to look up to and your now it. At my 64 yrs I'm running out of mentors and role models.
Maybe I'll buy that Option after all.
e
e
so much for
- The Canoe Guru - CBoats.net Sponsor
I took a solo Vertige X and enjoyed it. I used Esquif's three point anchor system, but I probably stood up for thirty miles and I hitched a ride on a raft about the same. I didn't have a pump, but used rafts like the shore to empty occasionally. I had a bottle of Old Crow that sufficed as a bailer after the first couple of days...
I will take a SpanishFly next time. Raft support is the way to roll!
www.thecanoeguru.com
I rigged out a Wenonah Rendezvous. I knew I couldn't stay on my knees for very long, so I kept the factory seat, added knee pads, thigh straps, foot blocks, ankle blocks, a pump and filled it with float bags. I knelt when I had to and sat the rest of the time.
It was surprisingly dry, turned well enough for those rapids, was way faster than my normal OC-1 (nice for desperate ferry moves) and was comfortable. I even brought a bent shaft paddle for the long stretches.
I almost rolled it twice and bottom braced up once. It was great!
Is that delivered?open boater wrote:you want to buy one? I have a mint condition Whitesell stored indoors in Richmond VA. Still has the Whitesell airbags
$1300.00
to Scotland...?
The Whitesell I rented has a straight pedestal and straps, but it is just about stable enough to sit on the rear thwart to stretch out on the flat (I only fell in once doing that). Alternatively I found about 4 or 5 different positions I could kneel in with the straps off, half on or completely on. Knees out of the straps and thighs against the forward thwart was a good high position for paddling into the wind on the flat, you can drive the boat through knees and thighs, remain stable and avoid cramp.Einar wrote: How many used straight pedestal rigs with the weight on the knees and in thigh straps?
Occasional ride - I'll give you that one
After the swim on flat water I was invited onto a raft for the afternoon because the 2 worn out kayakers on it wanted someone else to talk to (it was a short afternoon anyway so I agreed). I also bailed out of the last day, knowing it didn't have any major rapids left and because the previous afternoon slog into the wind had pretty well drained all my energy. I did at least take some turns rowing the raft, man that's harder than it looks!
I'm familiar with seats and pedestals but what are the hydrid versions?How many used straight pedestal rigs with the weight on the knees and in thigh straps?
Oh, the big boy.. I've only paddled it as a tandem but would figure it's a fun boat on the grand.
I've heard several people liked their Sparks down it, as well. Fast enough to escape some of the bigger stuff, somewhat round chines (in some places). Should be fun.
Good luck finding a boat!
Jan
Jan
In 1998 I was on a 20 day supported trip. The open boats were a Probe 14, a Mad River ME, an Oncore and a Sunburst 2 along with several other kayaks and me in a Cascade C1. Of the open boats the Oncore performrf the best.
Oncore as in the Dagger Encore, from 1990 or so. 13 ft 2 inches
