Slalom boat basics?
mahyongg
Re: Slalom boat basics?
Post by mahyongg »
Btw. I watched the videos again and it looks like a typical Slalom technique, e.g. no catch, big blades to make up for the loss, a lot of splashing water around on entry. Really, you can determine an efficient stroke by the sound of it.. remember slow is smooth and smooth is fast.
JimW
Post by JimW »
I had another session tonight trying to remember various tips.
I'll be honest, I don't have great focus so was not always concentrating on my paddling properly, but when I was concentrating I was actually doing pretty well.
I was managing to paddle fairly fast, fast enough the keep the bow straight, and if I actually watched my bow it was hardly rising and falling at all. I think when I don't concentrate I don't rotate enough and don't get the paddle vertical enough looking from front to rear, which means I'm putting excessive yawing moment in, if I concentrate and get my top hand over the lower one it is much easier to power up without needing correction.
It was quite a short session, my ankles still struggle with C1. I used the flat water and the eddy, managed to get through the 3 gates in the eddy on one circuit but still usually committing too much edge to my cross bow break in for the amount of support available - sometimes I can catch it, but I took a swim too (was trying to roll on upstream side, almost had it but then the deck popped off).
I really need a slalom paddler to copy now :)
I think I have a lead for a local slalom club which I'll need to follow up.
This thread will be worth coming back to as I get the hang of it and I'm more able to try different things - at the moment I have a bit of information overload, but I'm grateful for all the tips and theories.
