need photo of a glassed-in anchor
slick
Post by slick »
Can I please get some photos of tie-down anchors glassed into a composite hull? Preferrably some lighter duty ones, like for a bag cage rather than for thigh straps. Something using 1/4" rope might be ideal. Thanks! --tw
NickParker
Re: need photo of a glassed-in anchor
Post by NickParker »
NickParker
slick
Post by slick »
Thank you, Nick! Those are in the right neighborhood. And gosh those Elfs look like joy on water.
Keep 'em coming, folks. Still need a photo of an anchor or tie-down made out of lighter duty cord glassed into a hull. --tw
kaz
Post by kaz »
I use 1" webbing, both ends frayed. Saturate in resin, place where you want it, lay on 2 pieces of Kevlar approx 2"x4". Use brush to fully saturate Kevlar and cover with peel-ply. First, sand the area thoroughly with 36 grit.
You may be able to see pictures of this on the Millbrook Boats facebook page.
JKaz......
kaz
Post by kaz »
Actually, if you look at the "kevlar Rival" pic from the Mike Yee website, you can see what I mean.
JKaz......
Mike W.
Post by Mike W. »
Here is a shot of my water jug anchor. I like to see the frayed ends of the rope while I'm working & when I'm done.
I sand the hull till it gets fuzzy. Tape the center of the rope w/ masking tape, leaving the ends untapped so I can fray them. Cut a slit in s-glass patches for the ends of the rope to go through. Put epoxy on the hull. Saturate the ends of the rope & s-glass patches. Cover w/ peel-ply & work the air-bubbles out.
The next day, tie a length of bungee between the rope anchors to hold the water jug & go paddle.
The process is the same for small or big rope. I do my strap anchors the same way, only w/ larger rope & larger patches.
slick
Post by slick »
Perfect! Thanks, Mike! --Tom
Mike W.
Post by Mike W. »
Glad to help!
