First C1 Boat
AU_Whitewater
First C1 Boat
I recently purchased a Liquidlogic Biscuit 65 shell to make into a C1. I'm trying to figure out what all I need to make it into one and the best way to go about it. So far I have a block of 3"x24"x24" block of foam and some hip pads. What would be a good option for a center rail that will be easy for a first timer to install. I have looked at the outfitting page, but have not seen much on c1 playboats. Also, how much more foam would I probably need along with some other supplies
Re: First C1 Boat
Try the search feature for this forum and you should get lots of C1 outfitting ideas.
Re: First C1 Boat
https://www.cboats.net/outfitting/" onclick="window.open(this.href);return false; and click on "RiverKen's GREAT guide to Outfitting" and you'll have A LOT of info to review.
The other links in that upper section to sub-pages (fence rail conversion, etc...) should also be really helpful.
Have fun, and good luck!
Re: First C1 Boat
I used a 100 x 50-mm PVC downpipe from Bunnings for a centre rail:viewtopic.php?f=2&t=7969491
