Foam side panels in mini-cell bulkhead boats?
BAD paddle
Post by BAD paddle »
L 'Edge, Blackfly, Silverbirch all seem to put some kind of foam side panel in their cockpits. Not so much in strap-outfitted boats. I'm assuming the reason is extra buoyancy; is there more to it?
Wendy
Re: Foam side panels in mini-cell bulkhead boats?
Post by Wendy »
! gallon of water weighs 8 pounds, so adding sidewall foam eliminates space for water accumulation.
Pierre LaPaddelle
Post by Pierre LaPaddelle »
Further to Wendy's comment, boats not equipped with bulkhead outfitting often require more in the way of customizing: anchors, tiedowns, etc. -- a good reason for not expecting the factory to foam the side-walls. That said, once your outfitting is complete, I think it's a good idea to add side-wall foam.
Rick
C'est l'aviron. . . !
