best cam-buckle?
best cam-buckle?
Who makes the best cam-buckle for 2" webbing? I just set up my Forplay & every time I ender I can feel the lap-belt loosen I'm using a plastic buckle that came from a dive-shop. I want to stay with a cam-buckle as opposed to a fastex for ease of release.
Thanks in advance.
Thanks in advance.
Go to a gun store that carries shooters supplies and buy a nylon pistol belt with a quickn release cam buckle. I think Uncle Mike's might be a brand name. They are similar to the lift up type buckles you find on rescue PFDs and work quite nicely. You can toss the belt which is rather stiff and use regular two inch webbing in its place. Drill a small hole in the lift tab and attach a wiffle ball on a short string making the buckle easier to find in those tense stressful moments when urgency is perceived or real.
use airplane seat buckles
I have two and they work great. I think the dive shops sell the metal buckles as well.
cheers
cheers
Fastex
Fastex is the brand I used with two inch seat belt webbing. You can either tie a note or get a Faxtex "keeper" for the non tightening end. These are available at climbing stores.
I like to set it up where I am pulling down toward the knees to tighten the tigh straps.
I am not a theoretical fan of lap belts,although I can see that they would keep the behind down.
Chuck
Chuck
I used cam buckles initially in my Delirious and after a close call because of a jammed and folded over strap (yes, it was very short)
I threw it out and replaced it with a VW beetle style lap belt, which has a very similar release mechanism as the airplane lap belts, with the main difference being weight as the VW belt buckle is plated steel and the airplane belt buckle is aluminum.
They release as easily under load as without load and don't jam when they get some dirt or sand in them.
I personally do not trust the cam buckles any more.
martin
http://www2.cip1.com/ProductDetails.asp ... %2D704LTBN
martin
Excellant Point
I wear a waste type of throw bag. I usually hang it up by with the cam buckle engaged. REcently, I did not leave any slack and found that it was almost impossible to release the buckle. Please take care if you are using a short peice of webbing as you might find yourself trapped.
Chuck
Chuck
One more vote for the airplane style buckle.
I think it is important that your restraint break cleanly at the buckle and not require a strap to run through a buckle.
I have used snowboard ratchets and found that, after a while, they bend and rust and can lock up.
I grabbed my buckle from an airplane and use it as a lapbelt. A friend of mine told me that airplanes carry seatbelt extensions for large people. They are a length of strap with both the male and female part of the seatbelt buckle. He found a sympathetic stewardess that provided one for him.
I can't help it
Did the stewardess provide him with the male or the female part????? Sorry but I couldn't resist.
Chuck Incognito
Chuck Incognito
Thanks for all of the replies. Martin, thanks for the link. I know I shouldn't consider cost on safety gear, but those airplane belts are pricey Do the VW buckles rust?
Saturday I re-threaded the plastic buckle that I have & it's a lot more secure now. I played hard the rest of the weekend & it only slipped a little once. I may stick with that for now.
Mike, I have used them for 2 years now, rivers only in the Summer (no ocean surfing, too far away for that) and pool sessions in the Winter. I do spray them maybe once a year with WD40.
So far there is no rust anywhere visibleon them. If I was using them on the ocean however, I think I would spray them after every use with WD40, that should keep them from rusting.
martin
martin
airplane buckles
go to a boneyard, they have tones.
Also uhmmmm, discreetly remove the ones on the airplane...so i did a bad thing .
