I occassionally reapply epoxy to the hull of my boat. The James river here in town has been a little low and about every 3-4 weeks I sand down the bad scratch/gouges and reapply a few layers of epoxy.
Problem is, I use the West Systems epoxy with the slow hardner and it puts the boat out of comission for a couple days (adding layers and cure time). Is there any drawback to using a faster hardner for this so I can get it back on the water sooner or should I stick with the slow hardner?
Hull epoxy
Not so sure that you will get back on the water any faster using either the slow or fast hardner. Both require 1-4 days to achieve a full cure (although the temperature required for each to do so is different.)
Heat is the equalizing factor with epoxy. Bake your boat at 130 degrees F if you want a hard and fast cure.
Here is some reading if you are really concerned about such things:
http://www.westsystem.com/webpages/user ... 00-915.pdf
There is an 800 number included if you want to talk to a West System tech rep.
You could try some plastic or marine epoxy. I'm sure there are rolls of epoxy putties that cure quickly. I have a roll-up of PC-11 marine epoxy that I haven't tried yet, and a retailer here (Mountain Equipment Co-op) sells a tube of plastic epoxy for quick ABS repairs. Not sure of the cure times.
FYI, I had some leftover PC-7 epoxy from a repair, and I just spread it onto the bangs and cracks on my bow Royalex (no bangplate), just to see how it would hold up - but it's pretty brittle and basically cracks and chips off.
P.
P.
