Zephyr update
ChrisKelly
Wendy, thank you for the link to
the DP 8005 article. It was very helpful.
d-rings to abs
Dont use vinyl Ds. Get the ones made of ABS then use 3M. NOC and other outfitters should have ABS Ds in various sizes.
MotorCityOC-1
My experience with ABS d-ring anchors ended badly. IMHO they are too sensitive to miscalculations in the angle at which the d-ring itself will be pulled. There's no room for the ring to twist. If it does, it can easily crack the plastic and game over.
Maybe there's a different kind than the rectangular gray ones I'm thinking of?
ChrisKelly
Regardinbg the rectanular gray D-ring holders,
I've used them a lot. What I do is lose the steel ring and replace it with a loop of good climbing line.
However, I have pulled both the steel D-ring and the rope loops through the channel, leaving a very well glued in hunk of strong plastic with a ragged edge in my boat. I have migrated back to patches but would use these again. The 2 part epoxy works fine with them, but when they are in they are in. Chris K
I also don't like the hard d-ring attachments. 1) because I've cracked them and they're a serious pain to remove/grind, and 2) because I think with the smaller surface area and hard edges they put more stress on the hull - I've had stress cracks happen around these d-rings, but not vinyl bases.
If you're using the bases, a string loop instead of the metal ring sounds like a good idea.
PY.
PY.
ClassFive Boats
A dring , held down by a piece of polycarbonate ( lexan is a trade name for it) , and glued with 3M structural aheasive should do the trick. The ploycarbonate is stronger that the boat is and will not break. BTW, MEKP ( methal ethal keytone peroxide) not mek, is used for catalyzing resin. Perhaps the mekp might work better. Havn't tried it though.
Cheap outfittng upgrade checked out on Ocoee River
In an effort to get a roll I carved minicell to make roll aids, but got tired of fussing with it-----> so I got some pool noodles and put them between the airbag and sides (2 on each side) to foam the sides out. They worked great to keep the center of gravity low while going thru bigger water. The deep tumblehome can hold quit a bit of water, but now I blocked it and if they float out because I have swam I will have additional flotation. Okay- hammer me or try it!
Good to see the Helenator and my new lurker friend this weekend.
NZMatt
- Supporting Paddler
What do you need?
Hi Carole,
What do you need? If it's available here in Switzerland, I can ship it out to you.
Cheers,
Matt
Cheers,
Matt
NZMatt
- squeakyknee
Bulkheads great
but I got the straps to reduce the weight- easier than a diet
Also- lots of folks try out my Zephyr and with my short fat legs the bulkhead would be too loose for most folks.
- squeakyknee
