Paddle Length
Dweller
Paddle Length
Post by Dweller »
What's a good method for determining the length of paddle i should use when I C1?
From the "Paddles" section to the left..
Post by Sir Adam »
Shaft
Shaft length is best determined by your torso height and the type of paddling you plan on doing (Slalom boaters prefer longer paddles than rodeo boaters, for instance). In general the distance from the top of your shoulder to the waterline (or floor, when kneeling or sitting on an object roughly the height of your pedestal) is your approximate shaft length. Add blade length onto that and you've got total paddle length.
