zephyr outfitting
fchasw
zephyr outfitting
Post by fchasw »
We've got a new zephyr (just doing our part for the canoe market - yeah, esquif!).
The shop recommended 48" bags, but they leave a few inches of empty space in the factory outfitting. Way too small for my taste. I've seen a few people mention zephyrs here - what size (length) flotation bags are you using?
Also, what have you used to glue minicell in the boat (like for the knee pads, which come separate - I feel like I've seen references to problems with adhesives on the twintex.
Charlie
I've got 60" bags, front and rear - fills it out nicely.
No problems with contact cement, pads and the like are not in tension and it works fine. The problem comes in getting a good bond in tension - you need a high $ 3M two part adhesive or build a bulkhead. But yours is probably factory outfitted with the new glue or a bulkhead already.
Denton
Post by Denton »
I think the 60" bags would work well also. The 48" bags from my Quake still left more room for water than I wanted. Knee pads - I bought 1/2" thick self adhesive knee pads from Rock Creek Outfitters at the Ocoee. These worked very well and installed in 5 minutes - no messy contact cement!!
Denton
billcanoes
zephry
Post by billcanoes »
i have on of each- i think 48 in the stern
fchasw
thanks!
Post by fchasw »
This is a great help.
I do have the factory-installed straps, so I'll look into contact cement for the knee pads.
Charlie
greybear
Post by greybear »
What kind of glue does one use for the knee pads and where can one get it. Is it the spray 3M or is it similar to contact cement.
