outfitting materials other than minicel
bearboater
can't give you numbers...the other guy had access to UAB School of Engineering Lab, and tested a couple of different setups ...
he tested:
1) single lexan sheet laminated between two of foam
2) two of lexan between three sheets (foam- lexan- foam- lexan- foam)
3) a single corrugated lexan sheet between two of foam (this lexan was similar to corrugated paper, with folds-between two sides of plastic)
4) and of course just foam alone
he went with the foam-lexan-foam-lexan-foam ... it checked out much better that the rest... surprising the the single lexan did not blow away the foam only, as when load was applied it tended to list to one side or the other and then fail... i believe the corrugated was strong, but water adsorption was inevitable
he tested:
John Coraor
My current slalom C-1, like a lot of other slalom boats, uses a single thickness of blue foam because it is lightweight. However, I have to say that when comptemplating resistance of the potential hydraulic pressure without buckling or twisting, there is something reassuring about a 3" wide minicell wall that is lacking from a 1.5" blue foam wall.
