Prelude?? Is it worth it??
I was wondering if I could get some feed back on the paddling characteristics of the Prelude? I getting tired of the short life of Royalex OC's. Just can't seem to make the transition to a Taureau or the like. Want to stay with a true Open Boat!! I imagine I'll give in one day!!
Justin
Justin
it is durable ... this is of utmost importance to me ... I've got a Spanish Fly (same company, same plastic?) with several hundred trips on ClassIII-V... never patched, however it can be welded ... there's a reason kayaks are HDPE, too bad there's not more options for it in canoes
it is reponsive, you will not outgrow it quickly ... caution, may come with a learning curve, but that's part of the fun ... while it is quick, it's not squirrelly ... has good stability, considering it's length and rocker ... not real edgy
it is relatively dry ... however some mammoth 15 footer would be drier
it still looks like a traditional canoe ... sounds like that concerns you
will not require maintenance ... you can put it up wet, and it'll show no wear ... and Pyranha has always stood behind their boats
Detonator Function
You don't hae to be a world class paddler (would be nice to be oneDetonator Function wrote:I think the Prelude is the boat of choice for many world-class paddlers. Seems like an excellent boat for pushing your limits. I've never tried one, but it is on my list.
- Dooleyoc-1
Justin:
You would like the prelude, but it will take some getting used to in Colorado. It is a great boat for the southeast becasue it boofs so well and is highly rockered which makes it great for tight turns on rocky low volume steep creeks.
It will seem a little unstable and slow at first compared to an Ocoee if you're running pushy western water in CO ie Arkansas Numbers at 1200 cfs or Roaring Fork in Aspen at 1000 cfs or Clear Creek, Poudre, etc...
Having said that the prelude can paddle big water too. Try one out. It would be a sweet boat for shallow rocky CO runs like OBJ.
bamaboater
better try to get your hands on one, cuz I heard the aren't in production anymore.
it's a sick boat. I'm probably not going out of my way anytime soon to paddle something else. maybe a demo for the hades of it, but I'm not going to look for a new boat because I haven't even come close to maxing out my skills in this boat.
I can't compare how it boofs to a detonator because I haven't paddled one. But it's plastic!!!
