Cu-Fly - hole in de boat -Dumb!
Big Al
Post by Big Al »
Alright, so I get the CU-Fly and right off realized I need to install a bilge pump.The 1" hole I drilled for the outlet was only slightly above the water line and the Fly was taking in water through that hole when the pump was not operating. Dumb.
I re-drilled 4-6 inches higher and it's working great. I can douse darksiders really well while sitting in eddies.
Plugging the original hole I've got the one inch circular piece of plastic I cut out from the 2nd outlet along with marine glue and duct tape.
I looked at some kayak drain plugs but their diameters were exactly one inch. Is there a permanent and relatively easy solution out there to seal up that original dumb mistake?
Thanks!
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
:o plastic welder?... I'da just left it where it was and added a one-way check valve.
PAC
Post by PAC »
Al I have a plastic welder! Let me know if / when you want to borrow it.
Craig's idea of a one way would work too. :-)
I think you should put a spigot there.
jscottl67
Post by jscottl67 »
Add a relief zipper :wink:
philcanoe
Post by philcanoe »
maybe a large (stainless) fender washer, and a rubber liner
maybe some imaginative throwbag holder
or is at a place for a beer holder
Maybe a tap!
Post by Larry Horne »
i think it is perfect the way you've got it. duct tape
padlcnu
Hey Al
Post by padlcnu »
I think a nice cork would give the boat a lot of character....
Hope you are enjoing it.
DCC :P
