PAC wrote:It was a hope that some of the designers from DC / Penn State of past would post on this. I'm sure they, in their efforts to build the fastest slalom boat, toyed with the idea of a keel or keels. Maybe even tested them in the Navy tank.
Paul:
I had been keeping out of this discussion as the original post asked for empirical data on the effect of a keel. Having none, I didn't feel that I had much to add. However, as not having anything intelligent to say has never kept me from opening my trap in the past, why break with tradition!?!
I would agree with the remarks made in several posts that the presence or absence of a keel impacts any given boat's performance less than other major factors of the boat's design like rocker, waterline length & width, and wetted cross section. Put a keel on any OC slalom boat and it will still turn more readily than a Jensen cruiser.
However, does any of us really doubt that the same OC slalom boat without a keel would turn more readily than its keeled cousin? If you think about it, a keel extends the profile of a canoe deeper into the water, providing more surface area in the water (i.e. friction) to resist lateral forces, while only nominally increasing friction when moving forward, the same principles that Jensen used in design of his long, lean, cruisers. Hence the effect of a keel in lessening lateral drift on a windy lake and to a certain extent in facilitating tracking when moving forward.
A keel's effect on lateral drift is probably somewhat similar to adding enough additional weight to a similar keelless boat to sink it the same distance lower in the water as the height of the first boat's keel. However, weighting a keelless boat would also reduce its forward speed due to increased drag. Typically you only find keels on general purpose/multi-purpose (i.e. "do no purpose well") canoes, usually with relatively flat bottoms (for good primary stability), in order to make such flat-bottomed boats track a bit better than the design would otherwise achieve. Adding a keel to a Jensen cruiser would be superfluous and to a slalom boat, counterproductive.
Of course, there are other ways to achieve the same purpose as a keel, including using a shallow vee hull, which also increases resistance laterally, but has the advantage of being able to constructively negate this effect when laid over on its bilge, thus making for both better tracking and better manuvering if paddled properly.
Getting back to slalom boats, they are an interesting case study as by definition slalom boats are designed to maximize two characteristics that are typically antithetical - maintaining good tracking to increase forward speed while enabling quick turns upon demand. While you won't find a traditional bow to stern protruding keel used, there are some examples of shorter keel-like elements being used from time to time. Beginning in the late 90s it became fairly common to design slalom boats with "rails." These can be seen as short, shallow "keels" typically located at the chines. Often the "rails" don't protrude deeper than the rest of the hull as much as the hull between the rails is raised somewhat higher (like a very shallow catamaran). However, the amount of change in hull cross-section is usually pretty small, on the order of 1/4 to 3/8 of an inch, and is almost always limited to the center section of the hull. The intent is to facilitate tracking and thus speed when paddling forward, without hampering the ability to turn quickly when needed. Because a good deal of turning in slalom involves stern pivots - small, short rails restricted to the center portion of the hull don't seem to have much adverse effect on turning. Whether they actually help much with tracking is, of course, much debated.
So much for my free observations, which are, of course, worth every penny that you've paid for them.
