I need a bigger head bucket.
Big Dave
Location: TX or Where electrons flow and the winds blow
Post by Big Dave »
I have a problem and I am hoping that y'all can point me in the right direction. I am a real big fella. 6'2, 13EEE shoe and head to match. :o . I have started trying to get into white water. I took a four day learn to yak class last October :roll:. After "listening" to all yall I know I am going to be switching OC. My most serious problem right now is finding a good helmet that fits me well. I am using a Shred Ready T-dub because that is the only thing I could get on my head. It is too small. It is very uncomfortable, to the point of being a wee bit painful at times. The chin strap is no fun at all! The people at NOC told me that T-Dub was the biggest helmet they had. Something has to change. In fitted hat sizes I wear a 7 3/4 soft rim (base ball cap) 7 7/8 hard rim (full brim types like western hats). Since the helmets a hard by nature I would think the 7 7/8 would be closer to what I really need. Who makes a good head bucket that might work for me? Thanks for any help y'all can provide.
msims
Post by msims »
www.fnaheadgear.ca or .com?
They have big big helmets. You can customize the outfitting with all the extra bits. Expensive but a great helmet. 200 buck
________
RGV250
dj
Post by dj »
Big Dave I got a big melon as well(7 3/4), the only thing that I've found to fit is Pro-Tec or Cascade predator. These are full cut helmets that are still a little snug if I wear cold weather liner, but it's tolerable. I've looked at SR and some other shortys, they don't go up to 7 3/4. Maybe someone else will have more info, good luck.
Dave
Paddle-Eat-Sleep-Repeat
cbcboat
Post by cbcboat »
The WRSI helmets have removable liners in different sizes, may be worth a shot.
http://www.whitewaterhelmet.com/catalog.asp
Cheers
B
I wish more manufacturers made bigger shells for the bigger melons instead of just padding them less. It seems like they care about the pin heads more! :lol: Ever look at an old Pro-Tec in the smallest sizes? There's like 2" of foam!
Big Dave
Post by Big Dave »
Thanks for the input y'all. For bigger mellon folks like me it looks like FNA Headgear will definitely work. It also looks like Head Trip should have a couple of models that will work.
dafriend
XXL brain bucket
Post by dafriend »
Check out the Grateful Heads Hard Hit which is supposed to fit up to a 25" head. That should be pretty darn close to a 7-7/8 hat size.
I am a fat head myself and had a hard time finding a good fit. The Lidds Nato finally worked out for me. But I don't believe that Lidds is in business any longer.
Dave
