Best skirt for converted K1 to C1 boats?
Im having problems with my skirt popping off. If I miss my first roll I usually fall out of my boat with out pulling the cord. I know just make the first roll and this wont happen, but has anyone else had this problem?
the problem is that a C!er is positioned a bit further forward in the cockpit compared to where the yakker was. The tunnel in a standard yak skirt is therefore too far back, creating excessive tension which can cause the skirt to blow off. Depends on the cockpit rim design/shape and tunnel offset.
Your best be is to order a custom skirt with a C1 specific tunnel offset.
Monuntain Surf, SkirtworkS and Snapdragon will build custom skirts for you.
http://www.mountainsurf.com/
http://www.skirtworks.com/
http://snapdragondesign.com/
TGG!
TGG!
How much will a custom made, reasonably good quality skirt cost from Snapdragon?
Also, a not custom, all neoprene whitewater Snapdragon skirt runs about $100... a not custom, all neoprene Seals skirt for $150, is that enough better to justify the huge markup over Snap Dragon skirts? Is it better at all? I've used both brands though I wasn't paying attention to the quality at the time, and while I wasn't looking closely neither one stood out as better... would a Seals skirt last a LOT longer or is it just priced higher because its a more well known name or something and they can get away with it?
I can't talk about snap dragon presonally, but I just observed that my MS skirts are a lot dryier and last a lot longer than most other skirts that my friends use. I also have never had an MS skirt come off, as opposed to other skirts.
I will be an MS customer for life.
I have onbe skirtwerks skirt, which I would rate on par with the MS skirts.
Bottom line is, you get what you pay for. Fit, materials, workmanship.
TGG!
TGG!
- Marc Evans
I had snapdragon make a custom skirt for my Fink. Fit is really good. I have not put it to the test in a hole to see if I can get it to blow, but I doubt it will. Cost was $116 including tax (I picked it up at NRS - 8 miles away). I think it was less than 2 weeks between sending in the outline of the cockpit rim and having the skirt.
I'm sure the others are good too.
Marc
Marc
Which may point to a boat design difference as much as skirt quality - the Fink, and other "real" C-1s have a good bit smaller cockpit than modern kayaks (esp creekers) which means less surface area for the skirt - less area for water to pile up on.
[From what I understand, that thinking has influenced British sea kayak design (largely based on Greenland boats) - they see smaller cockpits as a safety feature as there is less likelihood of having your deck imploded by a wave. The ones I've tried (i,e, Nordkapp) weren't that hard to get in as the cockpit is angled a bit (up at the front, down at the back) and you slide forward into the boat.]
- oopsiflipped
- marclamenace
I am thinking of getting a "real" C1 skirt one day, but for now use an harmony LC-1. those are cheap and all neoprene so they kind of fit good even if they are not middle tunnel they adjust easily. probably not as dry though but hey, a stop to empty the boat also helps stretching your legs! ![:wink:](./images/smilies/icon_wink.gif)
I also use a snapdragon and have had no issues.Great customer
service,i had mine inside of a week.I'm sure at this time of year you could have it pretty quick,tell 'em the boat and it's a c-1 and you're good to go.You can even have 'em add a pink grab loop(or whatever your colour is) to accessorize!!!![:lol:](./images/smilies/icon_lol.gif)
