Tenesse paddling event in March?
I am looking for information about some paddling event in March in Tenessee, can you tell me more?
Francois
Francois
ALF
In mid March based around Lenor City,Tn. Depending on rain it has a little of everything from bigger runs to creeks, class 2 to 4/5.
Waldens Ridge Whitewater.com has info in its forums section about dates.
Bill
Bill
See:
http://www.cboats.net/cforum/viewtopic.php?t=7960221
Expect the chatter to start near beginning of Feb 2010
Signed,
You unofficial ALF 2010 non-event non-planner as it is an un-organized event NOT being hosted by Louie
Signed,
http://www.waldensridgewhitewater.com/f ... 4b941cec01
If you want the real low down call
Dick 865 986 9993
Doopey 865 986 6889
Andrew 613 558 9420
Louie 803 319 1719
Dick 865 986 9993
Doopey 865 986 6889
Andrew 613 558 9420
Louie 803 319 1719
here is the home page for ALF
http://www.waldensridgewhitewater.com/ALF.htm
Here is the forum for ALF
http://www.waldensridgewhitewater.com/f ... m.php?f=13
Here is what we are going to boat
http://www.waldensridgewhitewater.com/w ... inpage.htm
Most definitely, there's at least a hundred different runs to do within 2 hours radius.telemarkfreak wrote:... I run class 3 to 4, would it be fun for us?
I would caution against planing for certain on anyone area, allowing some wiggle room will allow you to access the best available area (due to normal rainfall distribution). I usually boat in N.Alabama-N.Georgia-or E.Tennessee, depending on where's the best water levels. A hour or two difference in camping, will make a big difference. The Smokies, Waldens Ridge, Cahutta, Lookout Mtn, Cumberland Plateau, and Sand Mtn. - all get extremely different amounts of precipitation within each front, and each has something to offer. The direction of front (weather pattern) will determine the best place, for instance in the Smokies Eastside to Westside.
calendar...
Added the Tentative dates for ALF to the calendar with a link to http://www.waldensridgewhitewater.com/.
Let the Admins know if there needs to be a change.
