You'll more than likely find me in the river paddling a...
I second (third?) Kaz, but I paddle my OC when the temperature is over 50F, my C! when it's under 50F approximately. My boat's to too tight to paddle comfortably with anything heavier than thin poly from the waist down and I'm too cheap to buy a drysuit.
By far most of the time in OC-1: an Outrage, but I'm interested in a Viper 12, Ocoee or something else sportier.
Dabble in C-1 coverts: Score and Redline, but not comfortable enough to run rivers all day.
Like OC-2: Vertige X, but only at "social events" when my wife paddles. Wouldn't mind paddling it more with other friends, just for a change of pace.
Pat.
Pat.
Probably the length would be 14' 9", which is about the C-2 racing length. There was a tendency back then to set cruising boat lengths the same as slalom or downriver length. It wasn't rational, but that's why we used to have all decked solo ww boats at 13' 2".
Otherwise let Louie Duet.
(This was in response to Cadster's post at the bottom of page 1 of this thread.)
- bushpaddler
OC2 (Esquif Blast) most of the time, at low water runs or in winter also a C2 (Canoah America)
Florian
Florian
- Mr.DeadLegs
what type boat
This year its been a Bell Ocoee all season. D-Caption
Mr.DeadLegs wrote:Does anyone make a commercial dedicated C-1?
Atom, Cascade, Fink, Wheelboy, a few that I'm not thinking of, a zillion and four different kinds of glass C1's plus the dreaded GyroMax (pronounced Year-Oh-Macks) just to name a few off the top of my head.Larry Horne wrote:No, not now. but all y'all keep patching up twenty year old boats so why should they
We really do need a *NEW* plastic C1 don't we?
Hopefully this time, the whoever the designer is will finally can the idea of pointy ends, and craft a balance between primary and secondary stability instead of emphasising the first*.Craig Smerda wrote:We really do need a *NEW* plastic C1 don't we?
*thats kindof an unfair critique, most of the C1's I've used have been slalom boats, which have tended to be wide, flat and not that happy with being cranked over steeply on edge.
Started the season in my Nitro, Picked up a Skeeter, still hit the ME once in a while or the Explorer on flatter water.
you'll see me in a borrowed boat once in awhile to try new things including a few C1's.
may see me in a conversian next season.
unless someones got a Hahn they want to donate.
these boats just get so expensive.
Proud Yankee
