Detonator Repair....
scott curtis
Post by scott curtis »
i was gonna say duck tape and bondo :P
jerm
Post by jerm »
If you run these things often, then just paddle your deto till it's dead, not worth the repair. Then buy a plastic boat.
FullGnarlzOC
Post by FullGnarlzOC »
I think i pretty much have to repair a lil bit.... or else it might sink before long lol.
I think im just gonna dynel the whole outline of the bottom of the boat using small strips overlapping strips.
I also need to repair an airbag, that has about 4 holes in it. I think Gflex/duct tape for that. I could repair a broken thwart, but frankly the duct tape has been working great with that. It allows the thwart to flex a little bit, which is good, because i think it takes alot of the pressure off of the other thwarts.
Um - I'm going to put some 'lock tight' on my footpeg screws, because they have been coming out during runs, which might cause me to miss a roll....and i cant have that.
ohh... whatelse - I have some D pads that came up, screwing the whole cage on the front airbag.
A strap broke... that needs to be duct taped....which basically will make the outfitting on that leg 'preset' for the weekend. aka no loosening or tightening during runs, without it being a major pain in the butt...
andddd last thing... I have a pump under my seat, that is held there...via... being under the foam seat. It slides around during large rapids/drops, and the hose pops off. What would be the best way to keep the hose on the pump nozzle? Like tight that it won't come off...but not too tight that it wont come off when i want it to come off
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
gumpy
Post by gumpy »
get a hose clamp from pep boys. just don't overtighten it or you'll crack the pump
Joe
