Simple Poll on Paddles
What type of paddle do you use the most?
All Wood - includes wood cores with outer synthetic reinforcement
21
40%
All Synthetic
19
36%
Wood blade and Synthetic shaft
4
8%
Synthetic blade and Wood shaft
9
17%
Total votes: 53
cadster
Post by cadster »
Four choices for whitewater use.
the great gonzo
Post by the great gonzo »
wood is good :D !
cheajack
Post by cheajack »
touch wood
Lengthy
Post by Lengthy »
I'm sportin' wood.
DougB
Post by DougB »
Wood shaft.
I don't get the glass shaft wood blade combo's....
TheKrikkitWars
Post by TheKrikkitWars »
You can't beat the good old Glass Werner Bandit, As much as I love my Mitchell Premier, the bandit remains my day to day paddle.
I really don't understand the Half and Half paddles...
Wood paddles are nice to use, tough as old boots, warmer in the hands and pretty;
Composite paddles are cheap as chips, tougher than old boots, lighter, and easily available everywhere.
But combo paddles are expensive special order items with a comparatively fragile join, and have uneven weight distributions....
philcanoe
Post by philcanoe »
a woody is good
Yukon
Yukan Canoe
Post by Yukon »
All this talk of Catherine Bach has gone to paddlers heads
SkeeterGuy86
Select Paddles Sponsored Paddler
Post by SkeeterGuy86 »
what ever is cheapest :( ... would love to be paddling creeks and everything with a Riverstyx paddle but currently use an old werner that i picked up at GAF for next to nothing
SG86
milkman
Post by milkman »
So what selection do you make in the poll for a carbon-shaft, carbon-covered wood blade, a la Mitchell? All synthetic?
TheKrikkitWars
milkman wrote:So what selection do you make in the poll for a carbon-shaft, carbon-covered wood blade, a la Mitchell? All synthetic?
I'm going to bet that if the carbon covered wood paddles go in "All Wood"... then carbon covered wooden blades with carbon shafts go in "wood blade - Carbon shaft"
coloradopaddler
Post by coloradopaddler »
I've used synthetic paddles since I started paddling, and still do. last year I got a Sawyer canyon guide (probably cheap to some of you guys) but I am really starting to like the wooden paddle.
TonyB
Post by TonyB »
huh..huh.. we said wood!
Proud Yankee
FullGnarlzOC
Post by FullGnarlzOC »
For what Im looking for. synthetic is by far the best option.
Did the whole wooden stick thing with hockey... and I would just break them. At least with composite I could replace the blade...
With canoeing, quality wooden sticks are just too much money to justify spending. You can get the same performance with a synthetic option, that is much cheaper. And you dont have to worry about breaking that "$250" paddle.
If u use wood because of the relief the flex gives to ur shoulder... there are plenty of synthetic options that offer shoulder and elbow relief.
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
the great gonzo
I have yet to find a syntetic paddle that has the same flex and feel of a good wooden stick and that lasts.
All the nice sythetics are too stiff for me. The inexpensive composite paddles just aren't worth it in the long run. A I wore a Bandit out in 1/2 a season, whereas a Backlund or Riverstyx lasts me 3 before it needs a rebuild. And they feel so much nicer, too.
